Actually, I suspect that the problem is not the thumbnail at all... and that there might not really be a problem. A texture map should be applied to a plain white model if all you want to show is the texture. You can "tint" the texture by painting the undermodel, and the resultant render will be a blend of colors. Many people go through their models and whitewash them if they intend to use elaborate texture maps (be sure to keep your originals safely somewhere). There is a python script to automate this in ProPack. Many modelers release the object in question as a white model, especially if they supply more than one texture map for it, and thus you'll get a white image in the thumbnail box. Carolly
I agree with Ron- If you apply a MAT Pose and then click the Add to Library button (the "+"), Poser will save the pose back to the library, NOT the MAT Pose. Since MAT Poses are basically "hacks" from cr2 files, there is no way to save a MAT Pose from within Poser. However, you CAN create your own, new, thumbnail (rsr) image: 1) Click the "+" button, but use a different name. 2) Open Windows Explorer, go to the PoserRuntimePoses(subfolder) folder. 3) Delete: the old rsr and the new cr2 files. 4) Next, rename the new rsr to match the old cr2. 5) Re-open the Poses Library and you'll see your new "thumbnail", but since it's the old MAT Pose, it will work just as before. --John
VanishingPoint... Advanced 3D Modeling Solutions
Today i bought a new character and installed in a new poser 4.03 installation. When i look in the pose library i get all flat white thumbnail pose files without colour. So the pose is hardly to see. The poser program is a fresh install. Can anybody help me .
