Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
If 105 looks distorted, then it IS distorted. 55mm is still close for portrait, 105 or thereabouts is a lot more like reality, like our eyes function. If your model looks odd at 105, you probably need to change it.... As to who it is.... I'm hopeless without any hair on her, but she is absolutely gorgeous! :] FishNose
I use an 85mm lens setting for the face camera. I don't know where you got 105mm as portrait standard. I've been a photographer for over 30 years and I would use (in 35mm format) an 85mm or a 135mm. The higher the focal length, the more it flattens out the face. Poser's default is at 25mm, which is almost "fish eye". Meaning it causes maximum distortion. Even the main camera setting is too low at 38mm, it should be set at 50 or 55mm for best results. As for the face, I'm guessing Toni Braxton, but I'd have to see her boobs to be sure. ;-)
Attached Link: http://www.photographytips.com/page.cfm/370
A normal lens typically has an angle of coverage of about 50 to 55 degrees and is roughly comparable to the useful or working angle of coverage of human vision (the peripheral vision areas serving mostly as a motion detection system). ---------------------------------------------------------- Lens choice for portraiture A short telephoto lens captures a subjects' head and shoulders in pleasing, natural-looking proportions. FOCAL LENGTH A lens that is approximately twice the focal length of the cameras normal lens generally provides flattering perspective for portraits. For 35 mm cameras, this is a short telephoto lens with a focal length in the range of 85 mm to 135 mm ---------------------------------------------------laughs Well, a lot of you guessed right. It is Brandy. I'm glad some of you got it right, but I can see where you get Toni Braxton. Just... not really Mya, so much. Once I find a hairstyle I like on her, I'll probably give a shot at a portrait or two... And then I dunno what I'll do with her. Intend to do some more tweaking on the morph tonight to get the face looking a little more like hers... Thanks for all the feedback! ^_____^
Kreations By Khrys
Kreations By Khrys
