Mon, Feb 3, 2:29 PM CST
Subject: Way OT. Windows don't ask to save files! How...
rwilliams ( ) posted Thu, 18 April 2002 at 8:33 PM ยท edited Sat, 25 January 2025 at 11:30 AM
When I used to click on a zip file I'd get a dialog box asking where I wanted to save the file. Now, when I click on a file the file is just loaded and openned. I can then copy the unzipped files from the window to a new location, but can't save the zip. Does anyone know how to fix this? Thanks in advance!
Lovely Lady ( ) posted Thu, 18 April 2002 at 8:41 PM
What version of Windows. In Win2000 you can under folder options and file types look at associations and click advanced and it has a box for confirm open after download there to check or uncheck.
ElectricAardvark ( ) posted Thu, 18 April 2002 at 9:18 PM
I had this happen when I had ME.When you click on a zip it would D/L it & extract it, without asking. Also it would D/L it before it asked you where you wanted to put it, which sucks for 135meg files. Ya know how I fixed it?...I got XP, heh.
droyd ( ) posted Fri, 19 April 2002 at 12:14 AM
This might help. I had the problem where freestuff downloads went to my temporary interenet folder and didn't give me an option either after it always used to. I asked about this here in the forum and solved the problem after I got the correct answer. I'm using Windows 98 but I would think other OS's have similar places to check for this. Here's the graphic I made for this, hope it helps.
droyd ( ) posted Fri, 19 April 2002 at 12:22 AM
Ok, I better add a little instruction, just in case it's not obvious or your OS is a little different. On the File Types tab in the Folder Options dialog box click on the Edit button and the Edit File Type dialog will open. All you should have to do is check the box "confirm open after download" and that should do the trick. Assuming of course you had the same problem as me!
rwilliams ( ) posted Fri, 19 April 2002 at 2:50 PM
I want to thank everyone for the help. I am using WindowsXP and using the info above was able to fix the problem. I don't know how it got changed, but now it is changed back. Thanks again!
Little_Dragon ( ) posted Fri, 19 April 2002 at 9:51 PM
Worked for me (Win98 First Edition)! Thanks, droyd!
Marque ( ) posted Wed, 15 May 2002 at 5:29 AM
I have win2k pro, and I also don't know what changed it which bothers the hell out of me. Thanks for the fix though. Marque
DreamstoGo ( ) posted Wed, 15 May 2002 at 11:16 PM
worked 4 me!!! thanks Andy!!
