Sun, Feb 2, 2:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: Questions on Boxing Accessories.
kalirage ( ) posted Sat, 29 January 2000 at 8:34 AM ยท edited Fri, 17 January 2025 at 8:14 AM
Hi All, Thanks for the previous posts.... I'm new to poser, so hopefully you'll bear with me on a few newbie questions.. First is on using deformers - I've been trying to use it on the mens shorts to raise the waiste band and make the legs longer, but all it does is stretch out a sharp point. How do I 'stretch' them evenly? Also on the shorts, there is no texture map for them on the poser cd - Is there anyway to create a new one in poser? I found a nice pair of boots on this site, but I can't figure out how to conform them to the figure. I've tried importing the .3ds file and sizing it and replacing body parts with the model, but it only stays for that one frame... and there's a lot of frames... Also, can you use morphs on .3ds files to alter them (flatten the soles). I found the gloves (Thanks Mark :)but they're a little too cartoonish. Is it posible to create props in poser? Or do you use another program? Thanks for your patience. Its really appreciated :) Zach
Sprout ( ) posted Sat, 29 January 2000 at 9:13 AM
As far as deformers, I have the same problems. No idea. Secondly, you can make a texture template by downloading UVMapper from Steve Cox's page to the right. To conform they have to be conformable charcter (.cr2) for multiple frames. Did you try some of the boots that conform that are in the Free Stuff area? Yes, you can make props in Poser but it is somewhat limited unless you find more shapes to use than the basics that come with Poser. There are some at the Props Guild which is also a link on the right. Post all the questions you want, we were all newbies at one time. And there are lots of people here that are willing to help. :O) Sprout
DgerzeeBoy ( ) posted Sat, 29 January 2000 at 2:47 PM
kalirage, Re: the boots: after importing each as a 3ds, save each to your props library. As props, they can now be selected from the library and positioned on your figure. This will then allow you to re-save each to your library as a "smart prop" - one that remembers its parent position every time it's imported, the same way a hair prop does. Chapter 6, of the user guide, under "Adding props to the library" will talk you through it. It's easy. Good luck...
