Tue, Dec 24, 8:54 PM CST
Subject: Transmap woes
kbennett ( ) posted Tue, 23 April 2002 at 4:24 PM Ā· edited Fri, 22 November 2024 at 11:59 PM
I'm trying for the first time to use transmapped clothing. I have a problem in that even with the transparency set to 100 there is a ghostly image around the parts that should be completely invisible. Is the clue fairy in town?
Tashar59 ( ) posted Tue, 23 April 2002 at 4:35 PM
Try Trans Min on 100%, and sometimes I find to lower Highlight and transperancy to 0. Or maybe your transmap is not black enough. Hope this helps. Tashar 59
kbennett ( ) posted Tue, 23 April 2002 at 4:47 PM
Unfortunately not ;) min and max are both 100, highlight is at min, transmap is pure black.
Tashar59 ( ) posted Tue, 23 April 2002 at 5:04 PM
You can also turn visability off on parts of pants, check your lighting, sometimes changing the light angle helps. Tashar 59
Tashar59 ( ) posted Tue, 23 April 2002 at 5:09 PM
P.S. Is your Highlight color black? Tashar 59
Seravajan ( ) posted Tue, 23 April 2002 at 5:15 PM
Can it be that the reflection map is still active for the legs? Seravajan
kbennett ( ) posted Tue, 23 April 2002 at 5:39 PM
Yeah, I turned of parts of the pant legs, and that hid those parts of course, but I can't switch of the 'shorts' element or the whole thing disappears. The highlight colour is black yes. Should it be?
As for reflection maps I don't have any loaded at all, just the slider set to 0.
Thanks for the tips guys, keep 'em coming :)
Netherworks ( ) posted Tue, 23 April 2002 at 6:02 PM
did you make the transmap?
jaybutton ( ) posted Tue, 23 April 2002 at 6:07 PM
I had the same problem a couple months ago. I solved it by using the same black map for both the texture map and the transparency map. Then I set the the transparency minimum and maximum to 100%. Let me know if this works, I am working from memory. :) Jay
sirkrite ( ) posted Tue, 23 April 2002 at 7:46 PM
The Black you are using for the Highlights has to be the Black from the bottom left hand corner of the Basic Colors, any other black will show up. Also! Make sure you set that for all the Materials that clothing item has.
chohole ( ) posted Tue, 23 April 2002 at 11:43 PM
and make sure your reflection colour is set to pure black, even though you have no reflection applied
The greatest part of wisdom is learning to developĀ  the ineffable genius of extracting the "neither here nor there" out of any situation...."
kbennett ( ) posted Wed, 24 April 2002 at 1:38 AM
Bugrit. Still no joy. I think the transmap (which I didn't make) is okay as even if I just load the pants, make everything 100% transparent and render without aplying any texture or trans maps there's *still* this ghostly shadow.
Seravajan ( ) posted Wed, 24 April 2002 at 5:40 AM
Strange this looks really like a reflection or a transmap. Probably you should check this again. Seravajan
kbennett ( ) posted Wed, 24 April 2002 at 7:54 AM
Nope, definitely no transmap loaded. All reflection settings set to zero, min and max trans set to 100. This last pic doesn't even have a tex map loaded, it's just the basic model with all the parts set to 100 transparent, all 4 colours set to black. This is really doing my head in.
Grammer ( ) posted Wed, 24 April 2002 at 8:06 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=514493
here is the solution- you must load a texture which is black on the transparent parts Karl
kbennett ( ) posted Wed, 24 April 2002 at 8:12 AM
That sounds hopeful Grammer. I'll try it when I get home this afternoon. Thanks.
kbennett ( ) posted Wed, 24 April 2002 at 10:15 AM
Yaaaaay!!!! Many thanks Grammer. It works beautifully, just like you knew it would ;) Kevin.
