Thu, Feb 13, 4:14 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: 15 Minute Challenge: Beginning Formula Objects
twillis ( ) posted Wed, 24 April 2002 at 12:30 PM · edited Thu, 13 February 2025 at 4:09 AM
Hey, I've been having fun messing with formulas, and I think I've come up with a challenge to encourage those of you who haven't messed with formulas to get your feet wet. From the Assembly room, Insert a Formula. Double click on it to go to the modeling. Erase the formula that's there, and replace it with: x=10u; y=10v; z=1; Click on the Parse button. The result will be a 10x10 plane floating 1 unit above the z-axis. Here's the challenge: Change the z line to make the resulting shape more interesting. Hint: z can be a function of u and/or v, and, since they're already defined, y and/or x.
brenthomer ( ) posted Wed, 24 April 2002 at 2:40 PM
I dont know what the heck you are talking about... You know what would be nice maybe? A complete list of numeric commands you can use..is that even in the manual? I dont remember seeing it. -brent
twillis ( ) posted Wed, 24 April 2002 at 2:59 PM
It's in Chapter 20 of my version of the manual. I'll try to print a screen shot of the formula editor when I get home today, so that what the heck I'm talking about is a bit clearer. Meanwhile, here's one to try: z=x*y;
nyar1ath0tep ( ) posted Wed, 24 April 2002 at 3:55 PM
As a beginner, I can appreciate a challenge like this. So here's the formula: x=10*(u-.5); y=10*(v-.5); z=10-(x*x+y*y)/4; Apparently u and v vary from 0 to 1 (like in UVMapping coordinates), so I had to keep it at u-.5 and v-.5 to get a full surface of revolution. It looks like x and y limit the boundaries, and z is the real equation for the surface.
twillis ( ) posted Wed, 24 April 2002 at 5:53 PM
Very cool. The "u-0.5" trick is a handy one, also multiplying that by PI, or 2PI can be useful for trigometric functions. It does appear you can mix and match a bit; u doesn't have to be the variable for x, and so on. Anyway, here is a quick screen shot of the starting (boring) formula:
twillis ( ) posted Wed, 24 April 2002 at 5:56 PM
Slightly more intersting. Very slightly.
twillis ( ) posted Wed, 24 April 2002 at 5:59 PM
OK, now we are getting somewhere. Notice the "p1" variable in the last line. That's so I can animate this sucker.
twillis ( ) posted Wed, 24 April 2002 at 6:03 PM
Heck, while were at it, how about a formula texture. Formula textures are similar to formula objects, only instead of using u and v to generate x, y and z values, you use u, v, x, y and z to generate red green blue values. floor(x) is a handy function, basically it return the next lowest interger. For example, if x=4.317, floor(x) = 4, and x-floor(x)= 0.317. I use this to keep rgb values between 0 and 1, and it's an easy way to make stripes. ceil(x) works in a similar way.
twillis ( ) posted Wed, 24 April 2002 at 6:16 PM
Whee! And this animation only has two keyframes; p1=-1 in the first frame, and p1=1 in the last. The formula does everything else.
keithw ( ) posted Wed, 24 April 2002 at 7:39 PM
Hey Terri, I tried to place the black and white checkerboard texture on your animated formula. This is what I got
nivek_ ( ) posted Wed, 24 April 2002 at 8:37 PM
I don't know what I'm doing with this formula thing but, when I type stuff in it RDS crashes. The formula is: x=cos(4PIv)cos(72PIp1u); y=1; z=1; Is this formula impossible?
nyar1ath0tep ( ) posted Thu, 25 April 2002 at 12:07 AM
I think x has to be a function of u alone and y has to be a function of v alone, so I think x=cos(4PIv)cos(72PIp1u) would cause a circular reference that would crash the software.
Kixum ( ) posted Thu, 25 April 2002 at 2:37 AM
Here's Mine
-Kix
twillis ( ) posted Thu, 25 April 2002 at 8:15 AM
Very cool, Kixum. What was the formula? That shape would make a fun alien or monster, flying toward you to absorb your soul! Well, if that's your idea of fun, anyhow. nyar1ath0tep, I'm not sure that x has to use u, and that y has to use v (I guess I need to test this more). Plus, I'm not sure how RDS differs. nivek, I think that your x definition might be ok, and that the problem is have both y and z equal to a constant; the result would be a line segment at y=1 and z=1, with the width determined by your x formula, which might not be visible, or might confuse RDS. Try making either y or z a function of u or v, like y=10u, and see if that helps. keithw, I like the "checkboard" you got. Would make for a challenging game, don't you think? I'm not sure, but I think you could make a checker board that "stuck" to the shape, by defining the regions in terms of u and v. You might try a simple 4-square, with something like: a = floor(u2); (result should be 0 or 1) b = floor(v2); (result should be 0 or 1) blue = ab; (result should be 0 or 1) I think the result would be a 4-square checker board, but you guys might want to check my math. Um, might have to add some sort of fudge factor for u and v = 1, but I'll test it when I get home today.
twillis ( ) posted Thu, 25 April 2002 at 5:14 PM
OK, nivek, I've been playing with your formula. In Carrara, you can mix and match u, v, x, y, z. Not sure about RDS. Here's one adaptation of your formula.
twillis ( ) posted Thu, 25 April 2002 at 5:17 PM
But perhaps this was what you had in mind.
twillis ( ) posted Thu, 25 April 2002 at 5:27 PM
Also, it turned out that the checkerboard formula was a bit more complicated than I thought. This should work, and let you change the values of h and i to control the how many squares across and down you have. Nivek's formula is groovy, so I used it for this example.
DotPainter123 ( ) posted Thu, 25 April 2002 at 6:35 PM
I tried some parametric functions from by calc book and still yechhh! I need to play with this some more!
keithw ( ) posted Thu, 25 April 2002 at 7:51 PM
Thanks again Terri! It works perfectly. The checkerboard now moves with the animation. I had a little trouble with the formula until I figured out that || is not two lowercase l's and that both h and i should be equal. Keith
nivek_ ( ) posted Thu, 25 April 2002 at 8:15 PM
Thanks for the help twillis. I typed in your ammended formula and ended up with a small flat shape. But it didn't crash. Is there a difference between RDS and C formula?
Kixum ( ) posted Thu, 25 April 2002 at 11:11 PM
My formula.
-Kix
keithw ( ) posted Fri, 26 April 2002 at 7:00 AM
Here is Terri's animateable checkerboard texture formula applied to an animated formula object. No more changing patterns! Here's the formula I used for the animated object. x=10*u; y=10*v; z=cos(2*PI*p2*(4*u))*cos(2*PI*p1*(4*v));
Nicholas86 ( ) posted Sat, 01 June 2002 at 6:26 PM
I will be copying the information from here to my website for a resource for others. All users names will be sited. If you have a problem with me using your formula, please email me and we could work something out. Thanks you. I hope for more assistance from those of you who have a better understanding of formula
twillis ( ) posted Sat, 01 June 2002 at 9:26 PM
You're welcome to use anything I have posted here.
