Sat, Jan 25, 6:32 AM CST
Forum Moderators: Staff
Subject: Problem with multiple walk paths
Paul_spg ( ) posted Wed, 24 April 2002 at 12:27 PM · edited Sat, 25 January 2025 at 3:31 AM
Hello,
I have a question on a problem I'm having with Poser 4 and multiple walk paths. I want to have 6 Poser models with 6 walk paths. I am able to set up 3 but when I add the 4th walk path to the 4th Poser model I am unable to modify the walk path (curve). When I try to select the points on the walk path to modify the curve it will not select them. I am only able to move the whole walk path object in the x,y direction.
Is there a limitation on the number of walk paths or models you can add at one time? Could it be a RAM issue or a bug? Or am I messsing something up?
My system spec is PIII 450 MHz, 128 RAM.
If anyone out there can help me out on this it would be greatly appreciated.
Thanks,
Paul
ScottA ( ) posted Wed, 24 April 2002 at 10:13 PM
Looks like it's a system issue. I loaded all four casual people figures. Clicked on them and added a walkpath to each one of them one at a time. And I could still edit the walk paths. I use a PIII 1GHz, 128meg. Ram ScottA
Paul_spg ( ) posted Thu, 25 April 2002 at 5:32 PM
Hi Scott, Thanks for trying that out and the info. I'm not sure what I'm doing wrong or is wrong with my system. I've tried rebooting, starting from a saved Poser file with the 3 working figures, but after I add the 4th figure all the walk paths kind of "lock" and I can't modify the curve. Everything else works fine with 3 or 4 figures. If anyone has any info on what the problem may be with my system please let me know. Thanks, Paul
