Sun, Jan 12, 4:32 AM CST
Subject: Setting up network rendering... Any help? (More details of setup)
BobDeegan ( ) posted Wed, 24 April 2002 at 3:41 PM · edited Sun, 12 January 2025 at 4:28 AM
I have to PCs running XP (Desktop and Notebook) connected by a USB cable. Bryce and Bryce Lightning recognize the existence of both computers in that the IP addresses of the machines show in the status windows and a reddish circle with a lightning bolt are present in whichever machine I set as the client. But either way I try it, the host computer isn't able to get data to the client computer.
Am I missing something? Any help would be greatly appreciated!
Best to all,
Bob Deegan
cyber-organic ( ) posted Wed, 24 April 2002 at 8:41 PM
The network uses TCP/IP to communicate, and I don't think that using what amounts to a null cable (USB) can use that protocol. Can you transmit files or anything else (non-bryce) between them using that USB cable? You might have to get a traditional hub or router and set up a network the traditional way rather than try to use just a USB cable. I can't imagine it working that way. I just got network rendering set up today at work, and it is definately worth your time...
big_hoovie ( ) posted Thu, 25 April 2002 at 11:05 AM
you don't necessarily need a hub or router, depending on your setup. if you only connect to the internet via dialup, you should be able to just run a cat 5 patch cable between the two comps. if you are connected to the net through your network card, then a router is definitly the way to go(as vs. a hub) because with a hub, you need to set one computer up as a server. I have a netowrk set up at my home, and we use a router to connect all together, and to the 'net. Hope this helps, big_hoovie
Incarnadine ( ) posted Thu, 25 April 2002 at 11:39 AM
You could also just do a simple peer to peer connection via a fast ethernet card in both machines. A cross cable is required in lieu of the standard ethernet link. Much simpler and you don't have to go through the whole setting up a hub mess. (Note this applies to only TWO machines) This is what I use to connect my laptop with my desktop.
BobDeegan ( ) posted Thu, 25 April 2002 at 3:30 PM
Thanks folks! The Ethernet cards worked like a charm! Best to all, Bob Deegan
itsrainin ( ) posted Sat, 27 April 2002 at 12:20 AM
i had trouble getting lighting to work, everything looked ok but it wouldnt get the file info, I tried putting the file being rendered in a share folder that all computers could access and that made it work... hope that helps itsrainin
