Tue, Jan 28, 7:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: I am suffering
MJHCreations ( ) posted Mon, 29 April 2002 at 3:13 AM ยท edited Tue, 28 January 2025 at 12:26 AM
I have recently purchased Dina V and and the clothing packs, and I have noticed, if I move a certain body part, (hips, arms and neck--on Dina V)it drastically the fit of the clothing. This also happens when I attempt to rotate the model as well, making for some very frustrating posing. What if anything can be done about this. Guidance is extremely welcome and needed. Thank you
OJM ( ) posted Mon, 29 April 2002 at 4:33 AM
And how about not conforming the clothes but saving the Dyna Pose and then applying it to the clothes ? PhEn.
Marque ( ) posted Mon, 29 April 2002 at 4:53 AM
Yes but what if you want to do an animation? Marque
Strangechilde ( ) posted Mon, 29 April 2002 at 6:31 AM
I had something similar happen when using the Victoria clothes pack. Moving the figures did some most peculiar things to the clothing, and I could see the various parts of the clothes wibbling about as the figure moved... I have no idea why this is. The solution, I found, was to pose the figure without clothing, then load the clothing and conform. Kind of annoying if you're working on an animation, though, wouldn't it be?
Dragontales ( ) posted Mon, 29 April 2002 at 11:33 AM
I don't know if this is related to your problem, but I had a similar problem with Victoria as well. I put the catsuit on her and anything more than slightly bent would cause her to come thru the suit. What I finally found out was that because I scaled everything in the Y axis (I wanted her a bit shorter) that threw everything off. I rescaled her back to 100 percent, and it worked perfectly. Moral - don't scale figures in single directions. Hell, probably not in any direction. HOpe it helps. Dragontales
