Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 8:28 pm)
If you really want to get them "skinny", apply the body type you wish to use regularly, save as a CR2 (character), then edit the CR2 to remove body morphs you don't want (i.e., "heavy", "emaciated", etc...) from EACH body part. This will be work, but the end result will be a "slimmer, trimmer" Mike & Vicky. P.S. - Don't forget MS Excel is great for this kind of work.
Look in Poser above and go into the "Window" drop down. Check "Hierarchy editor." Then check the box that says "Show all parameters." It may take awhile to see the check and parameters. Depends on the cr2 size. Under "Body" you will see all the full body morphs. Click the up arrow icon next to the full body morph you want to delete. Then click your delete key on your keyboard. Your done! You can delete any morph in Poser by part or full body with this method. No need for another program. I generally save the figure under another name first in case I screw up. Like "Michael2 delete" or something. Ron
I've been trying to thin down some of my Vicky and Mike(2) charaters and have found no way to remove the un-used Full-Body morphs with MorphManager nor the Hierarchy Editor in Poser?
Are they worth persuing into a text editor?
