Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 08 8:23 pm)
That is looking good! You could do with some antialias on the bumpmap to reduce the jaggies. Either increase its resolution or try softening the bumpmap in your paint package, or a combination of the two. Also if you`re trying to directly emulate Sorayama you could add some blue colour into the top half of the reflection map. Try this link if you want to remove the ears, as Davo suggests. http://www.3d-cc.com/DL_pages/MS05.html Great work Mark
Yes Routeledge ... In fact, I won't change the metal reflexion texture but the lights colours .. but only for final render ... concerning 3Dcc link, thank you, but I'm not sure this morph could work on Vicky2 .. I'll try anyway :o) You're are right concerning the resolution of the map, I have to work on it, first I want to achieve the map, then rescale by 200% or 300%, bluring, then cutting the edges and bluring again .. pfiuuuuuuu ... lot of work still to do to get proper render :o))))) PhEn.
PhEn, Regarding texture creation, I hear you, and I sympathise B). Trying to create a Victoria texture of my own took weeks, sometimes I did over 100 test renders in one sitting. Any Victoria morph should work on both Victoria 1 and 2, so you should find it works okay. If however you intend to sell this character you would probably do better to create your own. BTW, Its now 11.25 in Paris, and youre later still!! Mark
lol ... I'm much more interested in harving some comments than diving in my administrative folders for the moment ... ok for the morph, "I'll go to bed less silly" (French expression translated)... well, about selling, I don't know ... I don't even think about posting ... I'll see when the work is finished (if happens one day !). anyway, thank you for all this comments ..
Here is a Bumps texture for the Sorayama Character ... It's using Vicky2, a Helmet prop found in the freestuff section, and Morphworld Reflexion map ... Thank you for comments.
