Sat, Feb 1, 10:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: "Memmap Vxd failure" Whats Up wit dat?
StolenHeart20 ( ) posted Tue, 30 April 2002 at 6:50 PM ยท edited Mon, 20 January 2025 at 7:04 PM
I dont know where else to ask this but um.. OK heres the deal. I have a AMD-K6 300MHz, 196mb (128mb + 64mb), and two 6.1Gigs HD running on WIN 2K. So I got another 128chip same as the other 128mb, both are the same..P133. After I installed the chip.. EVERYTHING was A-OK. Anyhow..I had to downgrade to WIN ME, cuz my couldn't run Mix Man Pro4 nor my Raindow6-Rouge Spear games. So why do I now get a error message after boot in windows a popup says "Memmap Vxd failure" Whats Up wit dat? Please help.. other then that everything is fine.. thats the only error I get.. HELP ME!!
ScottA ( ) posted Tue, 30 April 2002 at 6:56 PM
I've encountered this when setting up new systems. I belive it's video related. Try going into Control Panel->System->Device Manager and look for any exclamation icons. Then fix them. You might also try re-installing your video card drivers for ME. That might fix it also. ScottA
StolenHeart20 ( ) posted Tue, 30 April 2002 at 8:18 PM
Well hmmm i dont know... all i know is that i had WIN ME but its that i went to WIN 2K.... then i installed another 128mb to make 256mb.. and i went back to WIN ME... an i get the error
ScottA ( ) posted Tue, 30 April 2002 at 8:34 PM
It's just a guess on my part. When installing a win 98 system. If you choose the wrong video driver you'll get a "cannot find .Vxd" error. However, the "Memmap" wording is something I've never seen before. Try the Hardware&Technical forum. Those guys do a lot of system building ScottA
ronknights ( ) posted Tue, 30 April 2002 at 8:59 PM
Just off the top of my head, I suggest you remove the new memory and bootup the computer. If the computer behaves, then it's the new memory that's the problem.
ronknights ( ) posted Tue, 30 April 2002 at 9:02 PM
Just off the top of my head, I suggest you remove the new memory and bootup the computer. If the computer behaves, then it's the new memory that's the problem. *** Another question: Just how did you downgrade your operating system? This problem might have been caused by that downgrade process. This is pretty confusing. I just checked the Microsoft Knowledge Base. They have absolutely no information on Memmap Vxd failure. They usually have just about everything listed there. Ron
geoegress ( ) posted Tue, 30 April 2002 at 9:17 PM
Attached Link: http://www.simplysup.com/tremover/
Just for shits and grins- try using a trojan detector. this one is good shareware
