heyas; if you're brave, you can use the material summary instead of poking about messing with each individual body part material. save first, because the summary has been known to cause crashes. in the summary, you'll find one entry for each material (ie: skin, pupil, lips, etc etc). you can edit them there.
The above is a pz3 imported. I'm trying to use the Vue material-ing to create a wet look for the Poser figure. To do that, I wanted to make a mixed material. The summary seems to be working out. I'm still curious about the material split. Has anyone else worked with it? Doesn't look like Vue has parametric or UV mapping like Poser and Bryce.
