You can load both a .CR2 and its associated .OBJ, then generate morphed versions of the various body parts; Compose is probably just choking because Vicki2 is so huge. Remember it was designed some way back when figures only had a few morphs. (Lemurtek, look more carefully at the Read Files dialogue: it has three buttons. Input File reads .obj or .cob, Poser3File reads .pz3, .pp2, .cr2 or .hr2 :-) You can read more than one file at once.) Depending what you want to do in trueSpace, OJM, you'd want to convert either Vicki's geometry obj (for making morph targets or clothing), or a posed obj exported from Poser (for rendering). Hope that helps...
I'm just trying to import an Cr2 in compose. The one I take is based on vicky geometries and doesn't include any special parts or morphs. It starts loading and reading groups and morphs, but it stops and frezzes after reading 'Mouth TH' morph ... Does anybody have an idea about this problem ? My goal is to translate an Cr2 to .Cob format for use in Truespace 4. Thank you. PhEn.
