Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
Because "proper" texture settings doesn't necessarily mean that people have used the upper eyebrow portion of the map. There is no "one right way" to create a texture map. Some people use transmaps on the upper eyebrows and some do not. Just because your opinion is that one of these is correct does not make it so.
I did say it might fix the problem, and I'm no expert, but most of the millenium figure textures I have don't use the upper eyebrows at all, so I have to use the browgone morph, some use it and they do look more realistic because of it too, so it's six of one and half a dozen of the other, everyone's right and all the techniques work which is a blessing
"It Is Useless To Resist!" - Darth Vader
I have found it Ron, thank you ... but I think that is not what I'm looking for. I'm creating a MAT Pose file for Victoria. All settings for the Texture are in that file, you dont have to use the material editor any more then. Its for my texture I want to post and I want that it is possible to doubbleclick the Mat Pose and the texture is on Vicky :) All works fine except the EyeBrows. When I use my MAT Pose File all textures will be applied to the figure but not the EyeBrow texture. The base settings are all ok like object color, highlite color and so on ... but "Texture Map" is at "none" I dont know how to fix that ... I have tried that little prog in Freestuff too, MAT Pose Edit or so, but it dont work either. All textures were applied to the figure except the EyeBrow Texture :/ Now I'm sitting here and I have 10 more gray hair :) Chris PS: please excuse my poor english, but I'm mostly speaking in another language ;)
Attached Link: http://www.renderosity.com/~syyd/pntuts/mat.htm
Here is the Tutorial I ahve used to make my MAT Pose file: http://www.renderosity.com/~syyd/pntuts/mat.htm"It Is Useless To Resist!" - Darth Vader
Hello all, I have created a MAT Pose for V2. It contains all textures for the body and the head. The Problem: all textures are loading except the EyeBrows Is that a bug or have I made something wrong? I'm using Poser 4.03 Thanks for your help Chris
