Wed, Feb 12, 5:45 AM CST
Subject: Creating Mirrors that reflect
macmullin ( ) posted Thu, 02 May 2002 at 6:19 PM ยท edited Thu, 15 August 2024 at 8:14 AM
I am in the process of wanting to create a highly detailed Dyarama of a Ballet Dance Studio with one wall containg mirrors which refect the surrounding objects. My Question is can this be done in Vue and second how would I go about creating them. Dale MacMullin
bloodsong ( ) posted Thu, 02 May 2002 at 6:38 PM
heyas; yes, you just use a reflective material on them. vue has a ray tracing engine, so your scene can be reflected properly. i'm not sure with version 4 if there is a limit of how many reflected reflections you can have, or what happens when you hit that limit. but i'm working on a scene now that has a ground and a sky both with reflective materials, and nothing is turning out bizarre.
macmullin ( ) posted Thu, 02 May 2002 at 7:30 PM
Thanks Bloodsong its good to hear from you :-) If I create a line of flat plains what material and settings would I use?
bloodsong ( ) posted Thu, 02 May 2002 at 8:21 PM
heyas; well, i can't remember if there is a 'mirror' material, there may well be. i'd start with the silver, and then change the colour to be less bluish-grey.
Myske ( ) posted Thu, 02 May 2002 at 9:17 PM
There is a silver coloured and a yellow metal colured one. The plane I put behind the toyduck was done with the first. regards Myske
macmullin ( ) posted Fri, 03 May 2002 at 9:16 AM
Perfect! - Thank You Myske, I needed some visual proof that it would do the job with out going through all the trouble of building it, and having it all fail in the end.
Bop ( ) posted Fri, 03 May 2002 at 10:26 AM
Check the 'Basic' Material folder, there's a 'mirror' mat !
