Bryce F.A.Q (Last Updated: 2024 Nov 26 7:00 am)
You can texture the figure in Poser then use Steve Cox's UV Mapper on the links below right to import then export to Bryce. This UV mapper fixes something that Bryce doesn't like so your textures will look right. If the textures are lob sided or whatever then you can alter the coordinates. Hope this helps.
Go to PeterSharp's website for a good Poser to Bryce texture tutorial. It should answer any questions that you have. Neal
Go to Ed Baumgarten's site, you can find the link to it on the right side of this page under web resources. Once you get there click on 'tutorials' in the top bar, then click on 'poser text' in the left bar. This will bring up the tutorial of how to add a poser texture to a poser figure in bryce 3D. It's a real good tutorial with screen captures to show you exactly what buttons to push and everything. It's the one that I used to learn. Oh yea, be forewarned that this tutorial was written quite a while back and the texture he uses in the example is not that good compared to what's out now, so your figure is not going to look real pale like the one in his tutorial. It's just the texture that he's using is all.
You can also get a tutorial from the ZoneFive site http://www.mindspring.com/~zonefive Under Tutorials Spike
You can't call it work if you love
it... Zen
Tambour
how can i use the textures for poser figures in bryce? i made several formats in poser 4 (obj.3dmf,3ds) and when i want to use the texture it doesn;t show up correctly, in bryce i choose edit 2d picture then i choose the bmp for the poser 4 figure HELP!!!!!!!
