Mon, Feb 10, 4:34 PM CST
Subject: MAT Pose Files
TalmidBen ( ) posted Mon, 06 May 2002 at 1:41 PM ยท edited Mon, 05 August 2024 at 12:17 AM
Is it possible to create MAT pose files without Poser Pro Pack? Thanks! Ben
SAMS3D ( ) posted Mon, 06 May 2002 at 1:57 PM
I am pretty sure the answer is yes, just not sure how to get the exact rsr for you...Sharen
the3dwizard ( ) posted Mon, 06 May 2002 at 2:40 PM
Attached Link: http://www.renderosity.com/~syyd/pntuts/mat.htm
Try this tutorial. I just save as a new figure and delete everything but the material info.
eirian ( ) posted Mon, 06 May 2002 at 2:46 PM
Take a look in the tutorial's section for the tut on creating MAT poses by Colm. In case it's not still there...the short version is: 1. Get the materials the way you like, then save the character/outfit/whatever as a CR2. 2. Open the CR2 in a text editor. The first few lines: { version { number 4.01 } figureResFile :Runtime:Geometries:(whatever) actor BODY { ...you keep. Everything between that, and the material settings (right at the bottom of the CR2, starts with: material Preview { KdColor 1 0.645182 0.50959 1 KaColor 0 0 0 1 KsColor 0.37499 0.296605 0.274937 1 TextureColor 1 1 1 1 NsExponent 30 tMin 0 tMax 0 tExpo 0.6 bumpStrength 1 ksIgnoreTexture 0 reflectThruLights 1 reflectThruKd 0 textureMap NO_MAP bumpMap NO_MAP reflectionMap NO_MAP transparencyMap NO_MAP ReflectionColor 1 1 1 1 reflectionStrength 1 } ...is deleted. You also delete a few lines at the very end of the file, that look a bit like this: displayMode USEPARENT locked 0 } setGeomHandlerOffset 0 0.3487 0 Then save what's left. Change the extension from .cr2 to .pz2 and move it into your poses library. Job done - though as Sharen said, you don't get an RSR that way.
devoutus ( ) posted Mon, 06 May 2002 at 2:53 PM
look in the poser Utilities section for MAT Pose Edit v1.4.1.
CryptoPooka ( ) posted Mon, 06 May 2002 at 3:27 PM
Okay. Mission: Learn MATs is a success. But generating an RSR ... how do we do that without saving actual pose info?
CryptoPooka ( ) posted Mon, 06 May 2002 at 3:55 PM
Never mind. :) Got it.
