Attached Link: http://www.renderosity.com/~syyd/pntuts/mat.htm
Try this tutorial. I just save as a new figure and delete everything but the material info.Take a look in the tutorial's section for the tut on creating MAT poses by Colm. In case it's not still there...the short version is: 1. Get the materials the way you like, then save the character/outfit/whatever as a CR2. 2. Open the CR2 in a text editor. The first few lines: { version { number 4.01 } figureResFile :Runtime:Geometries:(whatever) actor BODY { ...you keep. Everything between that, and the material settings (right at the bottom of the CR2, starts with: material Preview { KdColor 1 0.645182 0.50959 1 KaColor 0 0 0 1 KsColor 0.37499 0.296605 0.274937 1 TextureColor 1 1 1 1 NsExponent 30 tMin 0 tMax 0 tExpo 0.6 bumpStrength 1 ksIgnoreTexture 0 reflectThruLights 1 reflectThruKd 0 textureMap NO_MAP bumpMap NO_MAP reflectionMap NO_MAP transparencyMap NO_MAP ReflectionColor 1 1 1 1 reflectionStrength 1 } ...is deleted. You also delete a few lines at the very end of the file, that look a bit like this: displayMode USEPARENT locked 0 } setGeomHandlerOffset 0 0.3487 0 Then save what's left. Change the extension from .cr2 to .pz2 and move it into your poses library. Job done - though as Sharen said, you don't get an RSR that way.
Is it possible to create MAT pose files without Poser Pro Pack? Thanks! Ben
