Fri, Feb 14, 12:07 PM CST
Subject: Really annoyed this time...
Joerg Weber ( ) posted Tue, 07 May 2002 at 10:44 AM · edited Fri, 14 February 2025 at 12:00 PM
OK, I never post much around here - and most of the time I do post, it is because of some vue-update. OK, I removed my Vue several times, installed a brand-new version, updated it and so on... Well, most of the serious bugs, like the object-rotation bug are gone, but there is still a lot to be desired. Someone here said, that 4.06 is the most stable version of Vue to be available up to now... Forget it... ever tried to add a water-plane to a scene with a not-so-standard volumetric atmosphere (one with the sun sized to 400% and a lot of fog)? I tried it about 20 times today and guess what: even if I reduce atmosphere-quality to -1, it still crashes every time I try doing this. OK, so I am just blowing some steam here, but E-On could really try to get that damn programm a bit more stable! I really love my Vue, but I hate those days where all I get from my Vue is a bag of crashes. Joerg
Bop ( ) posted Tue, 07 May 2002 at 11:27 AM
Did you try to send a mail to E-On ? Eventually, try to send your scene to Steve Bell, he will probably find what's the problem with your settings.
gebe ( ) posted Tue, 07 May 2002 at 12:52 PM
Joerg sorry to hear that. Vue 4.06 is effectivelythe most stable. But sizing the sun to 400%, hm! I don't know if this is logic. Anyhow, all real bugs are to be brought to e-onsoftware with the sample scene, as Bop said already.
Joerg Weber ( ) posted Tue, 07 May 2002 at 3:39 PM
Well I would like to send that scene to E-On... If I could finish it. But most of the time it just crashes before I get to save anything. But the error is quite simple to replicate: Use a volumetric atmosphere with volumetric sunlight, resize the sun to more than 100% and then add any object with a reflective or slightly transparent surface - and it's goodbye Vue... Joerg
gebe ( ) posted Tue, 07 May 2002 at 4:11 PM
Joerg, I would like to try out, but my computer with Vue 4 installed is ill at this moment, it only comes back from the hospital next friday (I hope!!!). Maybe somebody else could be so kind to try? Thanks. Guitta
Axe555 ( ) posted Tue, 07 May 2002 at 4:14 PM
Hmm...Just tried it and it went fine with 4.02. (Yeah, I know, I need to upgrade to 4.06 eventually) Rich
kruzr ( ) posted Tue, 07 May 2002 at 5:07 PM
Afternoon Joerg . . . 8^) After reading your post, I thought I'd give your example a try. I'm sure you won't appreciate this, but I didn't have any problems at all, creating or rendering the scene. I had the Atmosphere in the volumetric mode / the fog was set to density = 800 / the sun was size = 400% / the sun was volumetric / volumetric lights were on / the water plane was added / then I threw in a terrain with some Palm trees on it. The only thing I noticed was it took me an hour & 20 minutes to render in final mode. Using Vue 4.06, full update. My system is a PIII 500 / 512 mgs ram / Windows 98SE / DirectX 8.1 / TNT2 Ultra with 32 mgs video ram. So this is why it took me so long to render on my system. If your using a Mac, then I don't think my post will help you much? In all honesty, I don't think it's a bug or problem with Vue 4.06, or it wouldn't have worked on my system. Maybe it's a compatibility issue with Vue 4.06 & your video card, or drivers, or somewhere else? I don't know if this will help you at all or not, but I hope you can get it figured out. I'm sorry that I can't be of more help than this & you have a good one . . . Mark. ;^)
audity ( ) posted Tue, 07 May 2002 at 6:05 PM
I did also a few tests and no problems for me either... I'm using VUE 4.06 on win2000 (PIII-512Mb ram).
I only managed to crash VUE 4.06 by using many different volumetric materials (shaded and additive lighting mode)on a boolean object.
Could you tell us when exactly does VUE crash ? during rendering ?
Eric
Joerg Weber ( ) posted Tue, 07 May 2002 at 7:29 PM
No, it crashes the moment I add the plane. Joerg
sittingblue ( ) posted Tue, 07 May 2002 at 8:35 PM
Joerg,
I would try a different atmosphere (a preset) with a brand-spanking new scene. Sometimes a bug can be traced to an obscure element (ie. lens fare disrupting the atmosphere saves).
Charles
Charles
Joerg Weber ( ) posted Tue, 07 May 2002 at 9:26 PM
No, I found out what the bug is: The scene is to complicated. I added several layers with semi-transparent material to create a dense-fog like effect in a volumetric atmosphere. This seems to have been a bit to much for vue and the programm usually says good-bye while rendering the preview. Joerg
