Hmm what have you done differently above to make the two pics?
Digital
WasteLanD
Attached Link: http://www.fusiondesignuk.com/curiography/tut-poser-to-bryce2.html
The one on the left is how the cleo hair imports from Poser into Bryce with the following tweeks: Diffusion is set to 100 Ambience is set to 18 Specularity is set to 10 On the right, same settings but transparency is selected and blend transparency is selected as well. This is according to Curio's tutorial which works for Michael's Wedge hair, but not this.ah, ok.... to make a transparency map (the thing that goes in the alpha channel), you need white where its not at all transparent and black where it is totally transparent. If you put it as grey (like what you've done by the sounds of it - i.e. using the texture map as the transparency map).... then it'll all be partially transparent which is what you're seeing in the right picture. So, you've got to make a transparency map for the hair, which is white where you want no transparency.... and put that in.
Digital
WasteLanD
As you can see the transparency map of the lashes (also of the hair of the tutorial) is not the texture of the lashes in grayscale, you have to do an appropriate transparecy map ( using UVmapper you can extract the map of the texture of the hair and than you can draw on it) or maybe there is a transparency map for that hair hidden in poser folder try to search it.
