Sat, Feb 8, 11:14 AM CST
Subject: Where to put props??? please help
Remslin ( ) posted Wed, 08 May 2002 at 12:41 PM ยท edited Sun, 02 February 2025 at 1:04 AM
can someone please help me and explain what to do after i download a poser prop. where do i put the files within poser, i have tried placing the files in folders but when i start the program they simply are not there, do i need to seperate library files ???
Questor ( ) posted Wed, 08 May 2002 at 1:32 PM
pp2 (poser prop) goes into a folder inside the Poser/Runtime/Libraries/Props/[foldername] If they're 3ds, dxf, obj or any other kind of format other than pp2 (ppz for Pro Pack compressed) they need to be imported into poser through the File Import menu and then added to the props library by the little add (+)sign. It would help a little bit to know what sort of files you've downloaded that you're having trouble with. Another possible problem might be that you are extracting to the props/[folder] directory with Winzip and have "use folder names" checked, which means the props are several layers deeper than they should be and Poser can't see them. Hopefully that's of some help.
Kelderek ( ) posted Wed, 08 May 2002 at 1:37 PM
The .pp2 and the .rsr file goes in a folder of your choice under: runtimelibrariesprops If they are placed there, you will find them under "props" in Poser. If there is a .obj file as well, it should be placed in runtimegeometries in a folder that the creator of the prop usually specifies in the readme file. If not, you can open the .pp2 file in a text editor, the correct path to teh .obj file is stated in the beginning of the .pp2 file. The .obj file must be in the correct folder, otherwise you get an error message when loading the prop.
Kelderek ( ) posted Wed, 08 May 2002 at 1:38 PM
You type faster than me, Questor ;-)
Questor ( ) posted Wed, 08 May 2002 at 1:58 PM
LOL Practice Kelderek, practice. :)
geoegress ( ) posted Wed, 08 May 2002 at 6:25 PM
copy- save- and print
jamball77 ( ) posted Wed, 08 May 2002 at 7:34 PM
Attached Link: http://www.3dtutor.homestead.com
so nice to be appreciated :) James Ball
Questor ( ) posted Wed, 08 May 2002 at 7:50 PM
I shouldn't niggle because that's a damned helpful image for people as reference. But isn't the Poser camera named CM2, not PM2? :)
geoegress ( ) posted Wed, 08 May 2002 at 9:16 PM
lol- ya- I never noticed good catch :)
jamball77 ( ) posted Thu, 09 May 2002 at 2:57 PM
another thing of note is that you can do some interesting things with the files by purposely changing the suffix. and then putting it where you'd like it to belong. for example having a hair prop not show up under hair where you'd like it! try it out. I'll try to get around to changing the camera no one's ever mentioned it and i didn't catch the typo, thanks.
