Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
The left hand gets a bit tricky. Instead of parenting the sword to the left hand, you parent the left hand to the sword. Now, if you move the sword, the left hand will move with it (because it's parented to the sword), but the right hand won't move (it isn't parented to the sword). You might say that it's a case of the right hand not knowing what the left is doing. However, when you move the right hand, the sword will move along properly (because it's parented to the right hand). And the left hand (parented to the sword) will move also, as intended. Confused yet? Good.
Hey cool it worked!! Thanks so much Little_Dragon! :) Yes, at first I have to admit I didn't know what the Inverse Kinematics was for.... and the Object>Change Parent option wasn't available for the left hand. So I turned IK option on for the left hand (had a feeling it could do something and then I looked at the Change Parent option and it was on so it worked! Thanks again :)
