Fri, Feb 14, 6:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 5:18 am)
Subject: Poser Pro Pack to 3DSMAX plugin problem
violatus ( ) posted Fri, 10 May 2002 at 6:56 AM ยท edited Fri, 14 February 2025 at 4:36 AM
I'm using 3DSMAX R3.1 and Poser Pro Pack SR2. My problem is when I try to import a poser scene into 3dsmax using the plugin. I select the scene I want to import, wait to load and then when I hit the "create" button I only get a box. If I try anything 3DSMAX freezes and I get an error message that an application error has occured and the application will be shut down. I use Win2000 with Service Pack 2 installed. The funniest thing of all however is that I have previously used the plugin successfully but after I formatted my hard drive and installed everything from the beginning I can't make it work whatever I've tried. Please let me know if you know anything abou this and thanks for your time and patience.
wolf359 ( ) posted Fri, 10 May 2002 at 7:58 AM
im not a MAX user but you should update your propack
installation to SR3.
it might help.
My website
triceratops2001 ( ) posted Fri, 10 May 2002 at 2:41 PM
this question always appear , but seems no real solution...
markdc ( ) posted Fri, 10 May 2002 at 5:36 PM
Attached Link: http://www.curiouslabs.com/support/html/techSupport.html
SR2 doesn't work (I used to have the same problem) download and install SR3. It's a free upgrade. Also, always start with a blank scene and delete any walk paths. If you still have trouble contact CL. They actually will get back to you in a couple of days.
