Sun, Feb 9, 3:33 AM CST
Subject: How to add a background image?
Laverboy ( ) posted Mon, 13 May 2002 at 1:20 PM ยท edited Mon, 03 February 2025 at 4:16 AM
Ive searched through the forum and pdf but cant find out how to add a background picture. how do u do this? thanks.
Kelderek ( ) posted Mon, 13 May 2002 at 1:24 PM
An easy way is to load a square prop, place it in the background and apply the background picture as a texture.
Laverboy ( ) posted Mon, 13 May 2002 at 1:25 PM
Will shadows and stuff still work?
Laverboy ( ) posted Mon, 13 May 2002 at 1:28 PM
Oh thanks btw ^.^
Kendra ( ) posted Mon, 13 May 2002 at 1:30 PM
There's also a command to "add background image" up in file I think. It's up there somewhere and it puts your image in the background without having to use a prop.
...... Kendra
Kendra ( ) posted Mon, 13 May 2002 at 1:40 PM
Also if you want shadows, download Runtime DNA's Infinity Cove. (www.runtimedna.com) Just fit your background to the texture map and you'll have shadows cast onto the background.
...... Kendra
purdon ( ) posted Mon, 13 May 2002 at 2:33 PM
In poser 4 I do "Import" and then select "Background Image".
Laverboy ( ) posted Mon, 13 May 2002 at 2:36 PM
Thanks for your help guys =p
queri ( ) posted Mon, 13 May 2002 at 7:08 PM
The only problem, for me, with using "Import Background Image" is that then the render has to be in that ratio. All my Bckgrnd Images are landscape rectangles and I usually do Square pictures. I've found no way around this. If I resize the window back to my size the background, instead of flooding the intire background, floats up in the air. ery annoying. Emily
doozy ( ) posted Wed, 15 May 2002 at 5:02 AM
Try this and see what happens: Import the background image to a scene with the same ratio as that background. THEN change the dimensions of the scene.
