Thu, Nov 14, 6:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: uvmap question please
Moonbow ( ) posted Mon, 13 May 2002 at 4:23 PM ยท edited Thu, 14 November 2024 at 1:14 PM
Could some kind soul tell me how to remap the frog to include a map for his belly and underside of his legs? I managed to make a map in uvmapper, but it shows just the top, and most, if not all, frogs do not have the same markings on the belly as they do on the top. Thank you in advance for your gracious help in answering all my questions:) Moonbow
PhilC ( ) posted Mon, 13 May 2002 at 4:56 PM
In the mapping options try Split by Position or Split by orientation. That will give you a top and bottom map.
Moonbow ( ) posted Mon, 13 May 2002 at 6:22 PM
Thank you so much:) Hugs:) Moonbow
Moonbow ( ) posted Mon, 13 May 2002 at 6:32 PM
hmmmmm, My uvmapper doesn't have a mapping option:( Is that something that just comes with a professional uvmapper perhaps? Is there someplace I can download a trial of a uvmapper that has mapping options? Sorry for all the questions.
bloodsong ( ) posted Mon, 13 May 2002 at 7:02 PM
Attached Link: http://www.3dmenagerie.com/index-goo.htm
heyas; go to my site and get the 'new improved zygote frog,' which has a belly skin material, over and under mapping, and it does dozens of amazing poison arrow and tree frog things ;) all uvmappers come with mapping options. it should be under 'map.' you should see planar, spherical, cylindrical, box, etc. unless your uv mapper isn't 'uvmapper.' you can get uvmapper at www.uvmapper.com. if you're using something else, you gotta be more specific ;)
Cybermonk ( ) posted Mon, 13 May 2002 at 7:02 PM
Nope you can do that in the regular version too. Look under edit menu, New UVmapp. Each one of the different kind of maps has options. Thats what PhilC is talking about.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Lyrra ( ) posted Mon, 13 May 2002 at 7:20 PM
Moonbow, Yeah just to confuse you there's a program called UVmapper - most of us use that :) Lyrra
Moonbow ( ) posted Mon, 13 May 2002 at 8:02 PM
Thanks everyone:) Bloodsong, does your bullfrog textures work with the froggy that came with poser 4? I saw it but thought it was for a different frog, since it said bullfrog:) I shall go check it out:) I will try all your suggestions for uvmapper too:) Hugs Moonbow
bloodsong ( ) posted Tue, 14 May 2002 at 3:40 PM
heyas; moonbow, those are all the p4 frog, althoug remapped and 'squashed and stretched' a bit. um, and morphed..... try it, you'll like it ;)
