Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Attached Link: http://www.3dmenagerie.com/index-goo.htm
heyas; go to my site and get the 'new improved zygote frog,' which has a belly skin material, over and under mapping, and it does dozens of amazing poison arrow and tree frog things ;) all uvmappers come with mapping options. it should be under 'map.' you should see planar, spherical, cylindrical, box, etc. unless your uv mapper isn't 'uvmapper.' you can get uvmapper at www.uvmapper.com. if you're using something else, you gotta be more specific ;)Nope you can do that in the regular version too. Look under edit menu, New UVmapp. Each one of the different kind of maps has options. Thats what PhilC is talking about.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Could some kind soul tell me how to remap the frog to include a map for his belly and underside of his legs? I managed to make a map in uvmapper, but it shows just the top, and most, if not all, frogs do not have the same markings on the belly as they do on the top. Thank you in advance for your gracious help in answering all my questions:) Moonbow
