Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
jschoen--simple solution to your morph problem--double click on the morph dial. Set the values on the dial for a minimum value of 0.000, the maximum value for 1.000 and the sensitivity to 1.000. That way, the umbrella only has two states, open or closed. Morphs work well for things that open up, down, or sideways, but if the morph requires part of the object moves in an arch (like opening a hinged lid or a book) the in-between states look bizarre.
jschoen wrote: but I kept getting garbage on the inbetween morph - You will. As a morph target scaling parameter dial is moved, the affected vertexes always move in straight lines. You would need a Poser model with each hinged or sliding part as a separate jointed part, and then wait until someone has put into Poser an ability for two parts which share vertexes but they are not parent and child, not to split apart in movement.
