Sun, Dec 1, 5:18 PM CST
Subject: French Poser Users! Poseur Francais!
hogwarden ( ) posted Fri, 17 May 2002 at 10:43 AM ยท edited Sun, 17 November 2024 at 3:30 AM
Just doing a tiny bit of research... Are there many users out there who have the French release of Poser or Propack? I'm making PB compatible! Howard:)
akin_ ( ) posted Fri, 17 May 2002 at 1:36 PM
Attached Link: http://akin.free.fr/poser.htm
Any problem Pal ? The main thing you should know is Poser uses different names for the internal folder, it's cool, but quite a nasty thing for programmers of helper application ! =)
hogwarden ( ) posted Fri, 17 May 2002 at 4:32 PM
Akin_... That must make it difficult to install stuff!! Small problem... Does the library structure look like this? If not, could you let me know what it is? I'm not worried about capital letters. Also, are the folder names the same words as appear in the right-hand bar in Poser? 'Cos they're not the same in the English version... the tab says "Figures", but the folder on the drive is called "characters". I am trying to make PBooost work for the French releases of Poser!!! Howard:)
Erdehel ( ) posted Sat, 18 May 2002 at 5:13 PM
Howard, That's exactly the way the runtime folder looks like in the french version of Poser. Robin
akin_ ( ) posted Mon, 20 May 2002 at 1:55 PM
Yes Indeed ! It's a major problem ! Dan from CR2Edit has managed to overcome it... Good luck ! If you need any more help, my mail is akin@free.fr Cheers, A'kin
hogwarden ( ) posted Mon, 20 May 2002 at 3:23 PM
Yep... It's all sorted. PBooost is now at 1.2... (although it's not up at Rosity yet.) and works for the French releases. The Compatibility tester is updated and in Freestuff. IM me if you wish to know where the actual PBooost is available!! H:)
