Tue, Feb 25, 5:00 AM CST
Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Subject: VUE startup BUG
GODspeed ( ) posted Sun, 19 May 2002 at 12:24 PM ยท edited Sat, 15 February 2025 at 5:18 PM
Just bought Vue 4 from local retail. Installs fine... no probelms. Run the program... no problems. Open samples off the CD... no problems. Goto make a new image, the templates open.. No problems. But when i choose ANY temp. CRASH! Comp completely locks up, and i goto restart. Ive tryed abotu 20 dif things... all same result. BOOM Called Tech support. All i get are a bunch of Indians talkin 1000 words per sec. I cant understand them, and they cant understand me. (Same damn thign with Toshiba Tech Support) ANYWAY... does any1 have or had this problem... if so... wtf do i do? try to return it? btw.. i have a 700mhz pent with 256 mb of ram. the box says i meet requirments. Please help. =(
stamate_filip ( ) posted Sun, 19 May 2002 at 12:31 PM
I don't think the problem is the PC. I have 233Mhz and 32 Ram and ir runs almost perfect. It crashes sometimes in the program and everytime I exit the program, but the rest is fine. It might be your video card. I heard it has problems with geforce cards. Try to disable opengl and to reduce the wireframe quality. Or download the latest patch. It might work. If you can't make it work try to return it, but I don't think you can because you already opened the package.
thorntoa ( ) posted Sun, 19 May 2002 at 12:32 PM
The only thing that I have seen with Vue that seems to resemble this is incompatibilities with OpenGL and some graphics cards. I'm not sure what the default configurations are for this? Go to file >> Options on the menu bar and turn off the OpenGL stuff. It might help. (Also, if you haven't already - try downloading the latest patch from Eon.) If things are still not working -- try coming back to the forum with more info on system configuration. See if others are running okay with your video card and OS combination . . . Good luck
Allan Thornton
linwhite ( ) posted Sun, 19 May 2002 at 12:37 PM
I had the same problem. I turned off openGL as suggested by the above two people, and it's been fine since. I also did the complete update to 4.06. Hope that works for you.
gebe ( ) posted Sun, 19 May 2002 at 12:45 PM
GODspedd, welcome here:-) First of all, when you open Vue, click at HELP--->ABOUT VUE and make sure you have version 4.06-02. If not, go to www.e-onsoftware.com and download the latest patch for Vue 4 (06 FULL UPDATE). If you have already Vue 4.06-02, create a new file in Vue. Then go in the menu FILE--->OPTIONS There uncheck at right USE OPENGL As thorntoa already mentionned, you may have a graphic card not compatible with Vue or OPENGL. If this doesn't help, write an e-mail to Steve Bell at sbell.support@e-onsoftware.com Please explain clearly and shortly your problem. I must say, that I did not understand what you mean with """But when i choose ANY temp...""" What is ANY temp? Please feel free to come back if you need further help. Guitta
GODspeed ( ) posted Sun, 19 May 2002 at 1:00 PM
what i ment was... any TEMPlate... those small icons with diff scenes on them.... theres the example ones.. and then u have a abotu 100 to choose from in the NEw file section... I can Open the program.. fine but when i make a new file then Choose what kind of TEMPLATE i want... it bombs... sorry for the mix up.
gebe ( ) posted Sun, 19 May 2002 at 1:01 PM
Have you disabled opengl and tried again?
GODspeed ( ) posted Sun, 19 May 2002 at 1:22 PM
1st off.. i have 2 diff cards installed. Since my E machine comes with a FX card Installed to the mother board... it only has 1mb of memory though, 4 weeks ago.. i upgraded it to a 16 mb card and put in 1 of my open slots. I just tryed both... same thing. Then.. i tryed your little OPENGL thingy.... I WORKS! HAHA :skipps around: stamate_filip, thorntoa, gebe, linwhite .... Thank you Guys/gals sooo much. =*) you guys are great. ur an awsome host gebe, i wish more Moderators on Rendersity were as fast an as helpfull as you and fellow members were.. again.. thank you all... im sooo happy... lol now i goto learn how to work this thing! i have 8 motnhs to come up with a 20 piece portfolio to get into uni of North FL for FX design. :sigh: the stress.... GODspeed
gebe ( ) posted Sun, 19 May 2002 at 1:31 PM
Attached Link: http://guitta.i.am
:-) You can have a look at my tutorials (to start with "Vue d'Esprit 4 for Dummies") and lots of others. Do not hesitate to see also the tots for Vue 2 and 3. Many are also helpful for Vue 4. The link to my page is above. Try also the tutorials you find here in the Vue section at http://www.renderosity.com/tutorial.ez?Sectionid=9 And if you need help, just ask:-). We are here. Guitta
