Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
If you're running short of space it can be worth deleteing the RSR files in the geometries folders... Poser will re-create them as it uses the OBJ files, but all those rarely used geometries needn't have the RSRs there. There is a utility for doing this... um... but I don't know what it's called or where it is. You can do a "find files" with the Geometries folder only, with *.RSR as the search string then select them all all hit delete. It's quicker than trawling through the folders manually. H:)
Start --> run --> command (or cmd if you're not in Windows 9x), cdgeometry directory (i.e. cd "C:Program FilesMetaCreationsPoser 4RuntimeGeometries" (use those double-quotes, by the way), and then: del *.rsr /s That'll work, provided you're using a windows based machine. With 2k and XP some more useful dos commands were removed, but that should still work. I can't be the only dos nut around, can I?
nuff said.. (this sucks)! is there a utility i missed to clean up files?
