Fri, Jan 10, 10:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: removal of RSR from geo folder..is there an easier way?
raz ( ) posted Mon, 20 May 2002 at 1:44 AM · edited Fri, 10 January 2025 at 10:42 PM
nuff said.. (this sucks)! is there a utility i missed to clean up files?
scifiguy ( ) posted Mon, 20 May 2002 at 1:48 AM
errr...easier than clicking on it and hitting "delete"?
raz ( ) posted Mon, 20 May 2002 at 1:51 AM
yes, easier thatn that.. theres a bunch o' them. (clickety click, clickety click...and writers cramp!!) :)
Netherworks ( ) posted Mon, 20 May 2002 at 2:02 AM
I'm not sure that I know what a geo folder is but you can use Find Files or Folders in windows and look for *.rsr Then select the ones you want to get rid of and hit the delete key.
aleks ( ) posted Mon, 20 May 2002 at 5:40 AM
are you sure you want to do this? next time you load any figure that has no *.rsr just *.obj, poser will produce one...
nukem ( ) posted Mon, 20 May 2002 at 6:24 AM
Hi, aleks I think raz is referring to the .rsr thumbnail files, not the .rsr files in the Geometries folders. The thumbnails are safe to delete.
raz ( ) posted Mon, 20 May 2002 at 6:40 AM
yes the thumnails.. i went ahead and dumped it all and am going to do a clean install. thanks
hogwarden ( ) posted Mon, 20 May 2002 at 9:35 AM
If you're running short of space it can be worth deleteing the RSR files in the geometries folders... Poser will re-create them as it uses the OBJ files, but all those rarely used geometries needn't have the RSRs there. There is a utility for doing this... um... but I don't know what it's called or where it is. You can do a "find files" with the Geometries folder only, with *.RSR as the search string then select them all all hit delete. It's quicker than trawling through the folders manually. H:)
steveshanks ( ) posted Mon, 20 May 2002 at 2:16 PM
just right click and arrange icons by type, then you should be able to drag select them all....which reminds me i must do mine LOL......Steve
whoopdat ( ) posted Mon, 20 May 2002 at 6:06 PM
Start --> run --> command (or cmd if you're not in Windows 9x), cdgeometry directory (i.e. cd "C:Program FilesMetaCreationsPoser 4RuntimeGeometries" (use those double-quotes, by the way), and then: del *.rsr /s That'll work, provided you're using a windows based machine. With 2k and XP some more useful dos commands were removed, but that should still work. I can't be the only dos nut around, can I?
EricofSD ( ) posted Mon, 20 May 2002 at 9:22 PM
No, you're not the only dos nut around and the only thing I liked about XP was that it uninstalled and restored my old OS flawlessly.
whoopdat ( ) posted Mon, 20 May 2002 at 9:44 PM
Heh, that's not saying much for XP then. I'm still using 2k, and I don't see myself "upgrading" any time soon. XP is mostly just visual changes anyway, aside from a few little things here and there that I don't need/don't want. Besides, 2k is rock solid for me. :)
