Sat, Jan 11, 4:40 AM CST
Subject: A finite water plane? (Is that possible)
Tempest ( ) posted Thu, 10 February 2000 at 8:47 PM · edited Sat, 11 January 2025 at 2:49 AM
Well I am making this picture that needs both a water plane and a ground plane. But no matter what it is either one or the other so my question is, is there a way to make a water plane that has finite dimensions other than a a voulmetric water slab.
picnic ( ) posted Thu, 10 February 2000 at 8:58 PM
What about trying to apply a water material to a 'square'. Just tried it and I think it might do what you need. Diane B
Tempest ( ) posted Thu, 10 February 2000 at 9:05 PM
You are a very bright person Picnic. After posting I tried that and it did work although it is terribly see through. Thanks for the help Tempest
adam ( ) posted Thu, 10 February 2000 at 9:34 PM
Maybe you should try lowering the transparency. I know this sounds crazy, but try it, it may work =) . -Adam
picnic ( ) posted Thu, 10 February 2000 at 9:35 PM
Thanks G. Try going into your material lab and mess about with the bump, diffusion and transparency (depending upon which water material you are using). I was able to make it much less transparent. Diane B
chalga ( ) posted Fri, 11 February 2000 at 7:15 AM
I'm not sure what you're trying to accomplish, but another technique could be to slightly rotate each plane so that they merge at a certain point and each goes up from there. Or rotate the ground plane so only it goes up. But I think picnic's idea would probably be the best.
Spike ( ) posted Fri, 11 February 2000 at 1:19 PM
Yep! As Diane said the way to go here is to use a Square. Spike
You can't call it work if you love it... Zen Tambour
Spike ( ) posted Fri, 11 February 2000 at 1:23 PM
Just thought of one more way You could use a terain. If done corectly could give some cool efects. Spike
Tempest ( ) posted Fri, 11 February 2000 at 8:44 PM
Thanks for the help guys. Tempest
