Tue, Jan 7, 8:14 PM CST
Subject: Lightersaber pieces.
tajshan ( ) posted Tue, 28 May 2002 at 12:21 AM ยท edited Tue, 07 January 2025 at 8:14 PM
Anybody know where I can find the lightsaber Luke made for himself in Return Of The Jedi? Thanxs. I remember there was only the handle so I will make a blade myself.
Little_Dragon ( ) posted Tue, 28 May 2002 at 3:12 AM
ChrisGFX has Luke's RotJ saber-hilt at PropsGuild.
If you have need of others, _dodger has Poser props (with working blades) of almost every lightsaber from the Star Wars saga (Obi-Wan's, Yoda's, Anakin's, Darth Maul's, Count Dooku's, etc.) in the Free Stuff at 3D Commune.
Chris ( ) posted Tue, 28 May 2002 at 11:58 AM
Attached Link: http://www.grafxcreations.com
thanks for the tip Little Dragon ;) ... on my site there will be a "Look like Lightsaber" the next week ... with working blade. Chris aka ChrisGFX
"It Is Useless To Resist!" - Darth Vader
Little_Dragon ( ) posted Tue, 28 May 2002 at 5:19 PM
I wondered what username you were going by, here. :)
Looking forward to it. I've been playing around with lightsaber animation effects in Poser lately, and can always use good hilts for closeups.
Test #1 (MPEG format, 195KB)
Test #2 (MPEG format, 221KB)
Chris ( ) posted Tue, 28 May 2002 at 11:59 PM
looks really cool ... how have you made that saber effect?
Little_Dragon ( ) posted Wed, 29 May 2002 at 12:09 AM
I did two separate renders in Poser; one of Sabrina with the saber, the other with the saber-blade alone. I applied postprocessing filters (blur, noise, alpha glow, etc.) on the saber-blade video in Adobe Premiere, then composited the two clips together using an Additive Dissolve transition. Too much noise, though. It looks more like a flame effect than a proper lightsaber. I'll keep working on it. It's a good technique for detailed close-ups, but for distance shots I'll probably just use a blade-prop with transmaps, maximum Ambient values, and minimal postwork.
bikermouse ( ) posted Wed, 29 May 2002 at 4:05 AM
Have you tried making a rod from a cylinder and in render:material set transparency: min to 100 max to 0 falloff to taste ?
Little_Dragon ( ) posted Wed, 29 May 2002 at 5:57 AM
Yes, but as usual I can't leave things as simple as that. I have to make it needlessly complicated with nested cylinders.
Here's my idea of a transparent blade prop (see image above). 100% Poser, no postwork, discount lightsaber hilt by JFStan.
bikermouse ( ) posted Wed, 29 May 2002 at 11:37 AM
EXELLENT - the wild stallions new drummer "Monty" Burns
