Raven, that's almsot identical to mine - but I run it at 1280x960, since that's the correct ratio for things to look right - 4:3. If you use 1280x1024 (as many here apparently do) that's 5:4, which makes everything a bit short and fat, so figures don't look correct, the way they should. However, not many monitors can do 1280x960. My 21 incher which is at the repairman at the moment, can't do it. But then I run that monitor at 1600x1200, so it doesn't matter. On this much older monitor I'm using now, the highest is 1280x1024, but I avoid that if I work with Poser or Photoshop and such. Use 1280x960 instead. But of course any res works fine for Word & Excel and stuff like that. Correct ratios for true proportions: 640x480 800x600 1024x768 1152x864 1280x960 1600x1200 2048x1536 These are all 4:3 ratio. :] FishNose
po2!! Wow! I just tried it. I booted Poser up, and without selecting anything, I just typed po2. And there was an interface like Kozaburo's (minus the pieces of Photoshop showing through). I just learned something! (for the gazillionth time here in Renderosity) This bears some playing with..... (...off to play....) - JimX
Only 14 inch at home - 17 at work - but I'm soon to get a new one for home. Setup is the same on both. Also, do you all know the trick about the wireframe background figure? For one, you can move it whereever you want like the other items but also if hold down the alt key (PC) and click the wireframe background figure, you will cycle through quite a few alternate posed figures. : ) Interesting, fun thread.
This thread is making me think, showing me some things I didn't know, and making me question some things I'm seeing. I tried the PO2 switch and many of my previews don't show up is this because I have propack and it saves preview images differently? Is there any way to over come this? Is there any way to get the Figures, Poses, Props, etc. menu to show up all the time instead of hiding when you click outside the document window? I notice that the pictures have the name in the upper left hand corner of the screen. Often times this does not show up for me, there's nothing up there. Any ideas as to why that happens or how to get it to reappear?
Admin: http://www.artistsagainstcensorship.com
Artist: http://www.skyewolfimages.com
I use PSP for the screen shots...File ->Import ->Screen Capture
You're welcome! Well I've tried the old interface and I sort of like it....it's a little harder for me to get around in but also a bit more versatile...all in all I think I'll stick with the new one.
Personally, I keep the dials to the left side of the screen as I am right handed. It's less distance between the keyboard and the mouse and I type in most of my dial settings. I spend most of my time with posing dials, so it's more comfortable for me.
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.
I want it back.
Hi guys , I was just sitting here wondering if I am using the most optimal workspace setup. I figured the best workspace design will come from you guys showing the ones you use, because lets face it this neighbor has the best posers in the world. So don't hold back show your stuff !! Thanks guys , there is no limit to the things you can learn here !!!! see ya
