Fri, Nov 8, 6:03 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 08 4:41 am)
Subject: Poser 4.03 to Bryce difficulty
Kolschey ( ) posted Wed, 29 May 2002 at 11:21 AM · edited Fri, 08 November 2024 at 3:32 AM
Hey all, I am building a new custom character. The original geometry was built in RHINO 2 and exported as .obj geometry. I am able to import this file into Carrara/Raydream or Poser 4.03 (with Pro Pack). Now when I export the figure from Poser as an .obj file, and then try to bring it into Bryce 5, I get the message: "Bryce 5 A file error has occurred (i/o, bad media)." Has anyone else experienced this? Is there a workaround? Many thanks!
Rochr ( ) posted Wed, 29 May 2002 at 3:03 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=690018
Try this one and see if it helps!
Rudolf Herczog
Digital Artist
www.rochr.com
Kolschey ( ) posted Thu, 30 May 2002 at 8:26 AM
Yes! Thanks to the #IND replacement function, the object imported properly with nary a complaint! Considering that this is not a rocket science issue, though, I reckon that Curious Labs might want to consider patching this wee bit of code in the next service release for their Pro Pack.
jelisa ( ) posted Thu, 30 May 2002 at 7:36 PM
Glad the #IND fix worked! -darlisa
