Mon, Feb 3, 7:06 PM CST
Subject: Deleting rsr files in the Pro Pack
ronknights ( ) posted Wed, 05 June 2002 at 9:18 AM · edited Mon, 03 February 2025 at 7:04 PM
If I understand correctly, Pro Pack doesn't need rsr files in the Libraries, since Pro Pack automatically creates png files whenever you load a given Library "section." Does Pro Pack need rsr files in Geometries? I've just done a "search and destroy" of rsr files in the entire Library structure. That was fun! Ron Message671422.jpg
thebert ( ) posted Wed, 05 June 2002 at 9:40 AM
Ron, Ron, Ron, ProPack does use the *.rsr files. Went you open a Library for the first time, ProPack search thru directory for the *.rsr and create the *.png for each and ProPack check each time you open a directory from the Library and will create new ones for any missing. So if you did a "search and destroy" on *.rsr and you have not used that Library directory you destroy the thumbnail image. Now on the Geometries Poser uses the *.rsr to load faster so the next time you load that *.obj file the *.rsr will be create. I hope you didnt empty the recycle bin now
The difference between stupidity and genius is that genius has its limits.
ronknights ( ) posted Wed, 05 June 2002 at 10:30 AM
OUCH. That was a bone-head error on my part. In my last purge, I selected over 4,096 rsr files in the Libary folders. I was able to recover maybe 2,000-3,000 before my computer decided to reboot itself. Some of those folders already had converted png's, and others I'm sure did not. I have to run to work now. When I return, I can do a nice hunt to see which things need to be reinstalled. Oh, the joys of being stupid! Thanks for the tip. Now I know what NOT to do, grin! Message671422.jpg
bushi ( ) posted Wed, 05 June 2002 at 11:25 AM
Please also be aware that some of the older, user-made figures used the larger .rsr to distribute the geometries rather then a .obj. Pro Pack does use them this way so if you have problems loading a figure you may have to use the RSR2OBJ utility (in freestuff) to extract the .obj file.
bushi ( ) posted Wed, 05 June 2002 at 11:27 AM
Oops - 'Pro Pack does use them ...' should read 'Pro Pack DOES NOT use them ...', sorry. ;-)
KattMan ( ) posted Wed, 05 June 2002 at 12:06 PM
bushi, thanks for correcting yourself. Pro-pack does not use RSR files except in these cases: THe OBJ geometry file does not exist but the RSR for the geometry does. Converting this to an OBJ file will cause Pro-Pack to use the OBJ file and ignore the RSR files. When first opening a library, any items that do not have a PNG thumbnail will be checked for an RSR thumbnail. If the RSR thumbnail is found then it is converted to PNG and the PNG is loaded. THe RSR thumbnail is later ignored. Now I did a few tests here. FOr the thumbnails I have found that it isn't really worth going through them and deleting. My average space savings here was about 1 or 2 percent. These RSR files are fairly small. For the Geometry RSR's it is advantagous to remove these. After verifying that I had all the appropriate OBJ files I deleted the RSR's for these OBJ's. Disk space difference for my geometries folder dropped by 30%. Hope that helps you make another decision.
bushi ( ) posted Wed, 05 June 2002 at 12:16 PM
Beg to differ on one point KattMan. I've had several instances where folks tried loading one of my older figures after installing the Pro Pack and simply could not get it to load geometries from the distributed .rsr file. The only solution was to use the RSR2OBJ to extract the .obj file.
Terry Mitchell ( ) posted Wed, 05 June 2002 at 5:20 PM
Hey Ron, don't feel too bad. I did the same bonehead thing by deleting rsr files in many many Poser Library files that I had yet to open in Poser. Hundreds of obnoxious Shrugging Guys now constantly remind me of the error of my ways.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Strangechilde ( ) posted Wed, 05 June 2002 at 5:46 PM
Maybe one of you could answer me on a point of curiosity-- what exactly is an *.rsr file? What does it do? I'm on a Mac, and we don't have them. I know that without them, there is no thumbnail image. But is it more than that? I'd just like to know. :)
KattMan ( ) posted Wed, 05 June 2002 at 8:09 PM
heh on a mac you don't need them and therefore you won't see them. At least that is a far as I know. On the PC they are used for two purposes. One to generate the Thumbnail image and the other is a conversion of OBJ files to a format that poser reads nativly or somesuch.
ronknights ( ) posted Wed, 05 June 2002 at 9:15 PM
I discovered my massive mistake just before it was time to get to work. Now I'm back home, tired, and feeling pretty darned stupid. I'm compiling a list of stuff that needs to be reinstalled. Hopefully I can put it all together. After all that maybe I'll backup everything. Maybe I need to install my backup program first. Are you saying there is very little advantage to removing all those rsr files? Do I need to keep geometry rsr files? I got pretty confused again.
KattMan ( ) posted Wed, 05 June 2002 at 9:54 PM
Ok in short. RSR files in the libraries won't give you very much space back by deleting them. RSR files in your geometries can give you maybe 30% of the space back. If you have all the OBJ files then I would delete the RSR files in the geometries.
ronknights ( ) posted Wed, 05 June 2002 at 11:04 PM
OK, thanks. That makes it clear. As far as I know all my object files have both parts.. However you'd describe that.
Strangechilde ( ) posted Thu, 06 June 2002 at 6:26 AM
Ah, thanks. Yes, it used to be that there was a bug with some files which when converted to Mac crashed Poser onload... the fix was to run it through the converter without the .rsr. It's since been fixed in MacConverter, but I was wondering if there was anything more to an .rsr than a thumbnail. That explains it-- and why there's an .rsr for .obj files. I am happy grasshopper.
hauksdottir ( ) posted Thu, 06 June 2002 at 6:49 AM
Strangechild, Mac files typically have a data fork and a resource fork. We don't notice that there are two types of information streams unless we are moving files between the different operating systems. Since this program was originally written for the Mac, it is possible that the .rsr information is the stuff we have tucked neatly away in the resource fork... just set out plain and obvious for PC users. The code has changed a lot since then, but I suspect that is where it started. Hmm... that is an interesting question... now I'm curious. Of course, anybody who worked in tech support would know what files are necessary and what they actually do before giving other people advice on what should be installed where. Carolly
