Distance mask and altitude mask are 2 different things. Make sure you use altitude mask. Then make sure your object is on the ground plane (if it's way above the plane it will render all white, the altitude mask is based on the ground plane). In your case since you wish it to be a lattice you'll need have your object below ground and the other half showing above the ground. When you render you'll get a greyscale map.
That's exacly what I did. I tried both altitude and distance renders hoping for better results, and neither one works (above is the altitude mask). It renders the ball parts as flat gray, and there should be a gradient. Maybe it's a bug in the Mac version. Or maybe it's a bug with the metaballs. Or maybe it's a different bug altogether, I don't know. I've noticed that metaballs don't always mask properly. I've tried it with the metaballs grouped and ungrouped (what I've found to be the bug with masking metaballs) and still, I get the same results.
I do a good deal of terrain work, and were not talking mountains... ...creating sphere and tubular shapes in the terrain editor borders on impossible, even with gradients. You're better off keeping it a boolean. WAY, way less polygons. BUT, I'm sure you want it a terrain, so you can, at the very least, export it, lol.... Wish I could help more, the key is gradients, but that is also the problem, it's very, very difficult.
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Freestuff | IMDB
Credits | Personal
Site
Agent Smith, that's more or less what I'm trying to do, but it doesn't seem to work so well with metaballs. I'm starting to think it's a metaball issue. The real reason I wanted it as a lattice is so I could more easily snap it to the ground, and to create the seam created by the molding process without adding a terrain to the booleans. I also like the user simplicity of one [exportable] object vs. 31 metaballs, 4 cones, and 2 spheres. I was able to get similar results to your sphere while using a sphere, but not with metaballs. The metaballs seem to render flat.
Yeah, even lattices sometimes won't snap completely to the ground either, depends on how much of the terrain map is filled with actual greyscale. Oh, you want the seam? Lol, always trying to get rid of it, I can see where it would come into play in the Jack, though, or green plastic army men. With the jack, you still might have to have two terrains to export, the main one and another for the "lone post", that one might not extrude so well. Of course, then again, earlier today I said terrain spheres were inpossible... AgentSmith
Freestuff | IMDB
Credits | Personal
Site
