Thu, Nov 28, 6:09 AM CST
Subject: HAIR problem
websitter ( ) posted Mon, 10 June 2002 at 8:39 AM ยท edited Sun, 24 November 2024 at 12:30 PM
can i set the trasparency of hair to zero during the setup????
for some models it's difficult work with trasparent hair...
sorry x engl:)
Valandar ( ) posted Mon, 10 June 2002 at 8:47 AM
Just use Display -> Element Style -> Cartoon W Lines. It will make the hair, and only the hair, cartoon with lines, so you can see exactly where it is as you set it up.
Remember, kids! Napalm is Nature's Toothpaste!
Patricia ( ) posted Mon, 10 June 2002 at 10:48 AM
Great tip! This should be in the FAQ....invisible hair is the cause of much swearing around here =;^)
websitter ( ) posted Mon, 10 June 2002 at 12:00 PM
thxs valandar hidden line or cartoon wlines ;) cool
DarkSkills ( ) posted Tue, 11 June 2002 at 9:37 PM
Yes! This thread is a life saver! I knew I had seen this tip before, but I couldn't remember where or what the exact procedure was. Thanks :)
Stay Focused.
Jim Burton ( ) posted Wed, 12 June 2002 at 2:54 PM
Jim is going to try and get around to adding MATs to the hair in question, sorry it hasn't been done yet! I think the best way to work with trans-mapped hair is have it load with transparency off, after posing you can then check the fit, and finally right before rendering click on a Mat Pose file that properly set the transparency. That is what I do on all my current hair, the Hollywood hair sorta predates MATs though, we didn't know how to do that yet! Anyway, DAZ should have the SanFransico hair upgrade up in a couple of days (yep, I finally did it!), I'll probably do this set next, I think I'm going to do a conforming model of the longer hair too, in addittion to the prop version.
