Mon, Nov 25, 7:43 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Squash & Stretch for modelling and animation
Chrisdmd ( ) posted Wed, 12 June 2002 at 12:26 PM · edited Fri, 22 November 2024 at 11:51 PM
I am trying to make a cartoon-type head so I can play around with bones for facial animation but I'm having a hard time shaping the face. I go into the vertex modeller, insert sphere, & then want to elongate (vertically). I go over to the Browser tray and use the stretch modifier but nothing happens in the viewports when I increase the %. So then I go and insert a sphere in the model room and then go back to the Assemble room where I can use the stretch modifier from the Properties tray, elongate vertically, and then when I flip back to the Model room to adjust vertices and make the face, I find the sphere hasn't changed to the shape I created in the assemble room. I'm probably overlooking something simple so if anyone can help me I wouold be very approeciative. thanks, Chris
twillis ( ) posted Wed, 12 June 2002 at 12:46 PM
I believe that the stretching you are doing in the Assemble room will not affect the individual verticies of the model. You can apply stretching and so forth inside the model room (I think it is under the Selection menu).
cckens ( ) posted Wed, 12 June 2002 at 1:06 PM
Chris, I am working on a tutorial that should be done by tonight for facial animation... It will be fairly comprehensive. Just couldn't get what I needed last night. Ken dork.gif
Chrisdmd ( ) posted Wed, 12 June 2002 at 1:23 PM
I found the stretch under the Selection menu but it is not interactive...you move the slider and then it happens. Sometimes you need to adjust only one vertiex of the cage to stretch say one side or one corner. I don't know how to do that or even if it is possible. Also, Ken...I'm really looking forward to the tutorial...please let us know ASAP. BTW...U DA MAN! Chris
bluetone ( ) posted Fri, 14 June 2002 at 5:05 PM
If you chose the vertices with the select/move tool, or the marque tool, then using the select/move tool you can move them to wherever you want. For that matter, you can use the scale tool in the model room and scale the model, but I think you have to scale the whole thing, not just portions of it. Hope this helps!
Chrisdmd ( ) posted Fri, 14 June 2002 at 5:29 PM
I guess I was looking for some type of deformation cage feature. Thanks, chris
