Fri, Nov 22, 9:51 PM CST
Subject: About cloths
triceratops2001 ( ) posted Thu, 13 June 2002 at 6:49 AM ยท edited Fri, 22 November 2024 at 5:28 PM
I am trying to made some cloths by max, and have some questions. The first one is the wrinkle of the cloth. I selected the vertexes and move outward a little, then export as .obj. And import into poser, I found the result like this. It dont seems like the wrinkle of a cloth. How can I make it? Bump map is not very good when taking a close up, so I want to made the wrinkle in the mesh. Hope someone tells me. Another question is about the max to obj plugin. I can only export triangle faces, if I change to polygon, max crash. I can only use the setting shows in the picture, if I change faces to polygon, it crash, what can I do ? Thx!
deestilo ( ) posted Thu, 13 June 2002 at 8:31 AM
see the # of Digits ? it's 12............. try to see Colm J. tutorial about export import here in rosity or at his site......... btw try 6. hope that helps dees
triceratops2001 ( ) posted Thu, 13 June 2002 at 10:56 AM
thx dees, but I can't find a tutorial by colm j here, also can u tell me where is his site?
deestilo ( ) posted Thu, 13 June 2002 at 11:02 AM
www.runtimedna.com feel free to contact me if you got lost dees
triceratops2001 ( ) posted Thu, 13 June 2002 at 11:18 AM
just got there , thank you very much dees!
