Thu, Dec 12, 10:40 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Transparancy Problems -PhilC help!
Blacksteel ( ) posted Thu, 17 February 2000 at 2:25 PM ยท edited Thu, 12 December 2024 at 8:09 AM
I am having difficultys with the transparency map that won't seem to go away any sugesstions? Robe Model and hair transparency by PhilC, A Very awsome model! Thanks for ANY help.. Blacksteel
PhilC ( ) posted Thu, 17 February 2000 at 4:21 PM
Hi Blacksteel, The "magic hair" prop was intended to be used on its own not in conjunction with the other hair pieces. If its not required simply delete it from the scene. I have included above the transparency/colour settings if required. If you require additional help, I am very happy to answer emails at pcooke@mis.net Regards PhilC
Paul Hafeli ( ) posted Thu, 17 February 2000 at 4:45 PM
BlackSteel: The problem you are having is usually cause by the Transparancy Falloff having a value other then 0. When you want to make something fully transparant the falloff must be set to 0 ( Zero ) Paul Hafeli
