Mon, Jan 20, 2:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: My groundplane texture isn't rendering!!! *getting annoyed*
Desdemmonna ( ) posted Sat, 15 June 2002 at 3:18 PM · edited Sun, 05 January 2025 at 12:29 PM
Using environment #10 from Elite Expressions as a backdrop and everytime I try to render a complete scene, the groundplane dissapears. I've tried everything I can think of...any ideas?
kayjay97 ( ) posted Sat, 15 June 2002 at 3:44 PM
I had that problem before. I was told to go to Display> Guides > and make sure Ground Plane was checked. Hope this helps!!
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
smerc ( ) posted Sat, 15 June 2002 at 9:04 PM
Yup make sure you have ground plane checked. That dog isn't going to hurt the little bunny is it? :)
Desdemmonna ( ) posted Sun, 16 June 2002 at 4:41 AM
groundplane is checked :( Until I can figure what is wrong with this image, bunny will be safe :)
kayjay97 ( ) posted Sun, 16 June 2002 at 4:47 AM
how about different lighting? I found the other day when I rendered a graphic I was working on the lights I was using darken the lower part of the graphic so much it looked like my ground didn't render.
Jerry McCant
Desdemmonna ( ) posted Sun, 16 June 2002 at 6:02 AM
I've tried that as well, used about 13 diffrent lighting settings (poser default, lights that came with character packs, a few from freestuff) and all the floor didn't render in any of them. Sigh I'll figure something out, or just postwork a floor in.
kayjay97 ( ) posted Sun, 16 June 2002 at 6:10 AM
Hmmmmmmmmmmm....... did you fiddle with the ground plane like move it at all? Maybe it moved down below the render point? Am I making sense?
Jerry McCant
cooler ( ) posted Sun, 16 June 2002 at 6:30 AM
have you checked the size of the ground plane or the location of the plane in relation to the rest of the scene? I have done renders before where I rescaled everything to put it in proportion & suddenly found everything floating in space when I forgot to resize the ground to the same scale.
Desdemmonna ( ) posted Sun, 16 June 2002 at 7:46 AM
I haven't bothered with the groundplane at all other than to texture it, and yes I understand what you meant kayjay97, I did that quite a few times as an utter beginner :) Cooler, I've checked the size of the groundplane, seems to be just fine in relation to the environment. BTW, I render with everything turned off (antiviral, messangers, taskmaster, etc) and am using cacheman. I wondered if the floor not rendering might be because the image is so resource intense as it is (for my poor decrepid system anyways) that that might be a factor...*sigh* not the case. I'll check again and give some of these suggestions a second try, might be something wrong with me and not Poser :p Thanks for the advice so far everyone, -Des
leather-guy ( ) posted Mon, 17 June 2002 at 1:07 AM
One thought occurs to me, I can't recall the circumstances, but I recall a similar problem regarding ground textures - i think I solved it sizing and superimposing a one-sided square on the ground plane - applied the texture to THAT, instead of the ground plane itself - all worked okay after that - seemed to me the ground plane is sometimes more a virtual reference than an actual object - don't know why. Hope your problem disappears - I find the environments from Graphons Elite Expressions site absolutely invaluable for a lot of my projects. Good luck
Desdemmonna ( ) posted Mon, 17 June 2002 at 8:33 AM
I''l try that... I've never had these problems before with the enviros either...
