Fri, Jan 24, 11:09 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Vertex Modeling
chuckerii ( ) posted Sat, 15 June 2002 at 10:37 PM · edited Fri, 24 January 2025 at 1:09 PM
I was wondering if there is any way of importing a picture into the vertex modeler to trace or use as a reference. For example, similar to "Photo Modeler" or "Canoma" where you could place vertices on the photo to create your object? I haven't worked with the vertex modeler much, and when I do, it seems a bit painful to get good results.
Kryoclasm ( ) posted Sun, 16 June 2002 at 4:05 AM
I don't think so, not in Carrara. Amapi should let you do that, if you installed it. Good Luck
mmoir ( ) posted Sun, 16 June 2002 at 9:50 AM
chuckerii, This is not a feature of Carrara, but there is a workaround.Map your pictures to the appropriate planes in the assembly room. Go to the vm modelling room then click on the scene preview window,then click the texture preview icon.(one of the round ball icons) You should now see your mapped image all the time in the scene preview window . Hope this helps. Regards Mike Moir
mmoir ( ) posted Sun, 16 June 2002 at 9:53 AM
Chuckerii , I forgot to say you have to create these planes and positions them appropriatly around the item you want to model. Any questions let me know. Mike
chuckerii ( ) posted Sun, 16 June 2002 at 2:32 PM
Thanks Mike... I'll give that a try. Chuck
VK ( ) posted Tue, 18 June 2002 at 6:26 AM
Other work around:
  1. Open picture in 2D vector graphics editor (Illustrator, FreeHand, Painter, PhotoShop, etc.).
  2. Create vector outlines (paths) along the contours of the object. Export as Illustrator file (EPS).
  3. Go to Carrara, create new spline object. Import Illustrator file to Spline Modeler.
  4. Take spline object to Vertex Modeler. Delete the "thickness" of the vertex object. Now you have polylines of your model's contours.
twillis ( ) posted Tue, 18 June 2002 at 7:51 AM
That's pretty slick, VK. I'm going to give that one a try. In fact, I think this would make a great "15 Minute" Challenge. What say you all?
VK ( ) posted Tue, 18 June 2002 at 11:21 AM
Actually, the file format should be *.AI on a PC. I don't know if CS for Win imports .EPS extension. The supported formats are listed somewhere in the user manual.
