Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
chuckerii, This is not a feature of Carrara, but there is a workaround.Map your pictures to the appropriate planes in the assembly room. Go to the vm modelling room then click on the scene preview window,then click the texture preview icon.(one of the round ball icons) You should now see your mapped image all the time in the scene preview window . Hope this helps. Regards Mike Moir
I was wondering if there is any way of importing a picture into the vertex modeler to trace or use as a reference. For example, similar to "Photo Modeler" or "Canoma" where you could place vertices on the photo to create your object? I haven't worked with the vertex modeler much, and when I do, it seems a bit painful to get good results.
