Forum Moderators: RedPhantom
Attached Link: http://205.122.23.229/ronknights/files/miketexture2.zip
You can get complete transparency with: (colors from left to right) White Black Black White The Highlight and Transparency Falloff sliders should be all the way to the left. Both TransMin and TransMax should be all the way to the right (100%). You may be getting the ghosting because transmin is at zero...I don't think that means the same thing to poser as having both sliders at 100%.
This is my first dealing with Mike, most of my use has been the P4s and some with Vicky. Even though I have assigned a texture for Mike's eyebrows they showed up as white solids. Experiance from Vicky was that the "upper eyebrows" needed the transmap but not the "eyebrows." Apparently Mike is different. I applied a transmap to "eyebrows" and they worked... almost. They're still white! Am I doing something wrong?
