Thu, Feb 20, 2:07 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 5:11 pm)
Subject: having a strange problem with Mike's eyebrows and lashes
MacXimus ( ) posted Sat, 15 June 2002 at 8:09 AM ยท edited Thu, 20 February 2025 at 2:05 PM
This is my first dealing with Mike, most of my use has been the P4s and some with Vicky. Even though I have assigned a texture for Mike's eyebrows they showed up as white solids. Experiance from Vicky was that the "upper eyebrows" needed the transmap but not the "eyebrows." Apparently Mike is different. I applied a transmap to "eyebrows" and they worked... almost. They're still white! Am I doing something wrong?
FyreSpiryt ( ) posted Sat, 15 June 2002 at 8:41 AM
Try putting transparency fall-off to zero, the highlight all the way down, and the reflection color to black as well.
tasmanet ( ) posted Sat, 15 June 2002 at 11:11 AM
Try these settings
ronknights ( ) posted Sat, 15 June 2002 at 12:42 PM
Attached Link: http://205.122.23.229/ronknights/files/miketexture2.zip
Actually, you have the DAZ Michael 2 textures, they come with a MAT Pose file. Go into the Pose Library, look for MAT Michael2. If you're using Poser 4.03, you want to use the textures that say "P4" as part of the name. The others are for Poser Pro Pack. ** If by some reason you prefer to do it "the hard way," then you can download my Michael Texture tutorial. You'll find all the screenshots there. Ron
scifiguy ( ) posted Sat, 15 June 2002 at 5:37 PM
You can get complete transparency with: (colors from left to right) White Black Black White The Highlight and Transparency Falloff sliders should be all the way to the left. Both TransMin and TransMax should be all the way to the right (100%). You may be getting the ghosting because transmin is at zero...I don't think that means the same thing to poser as having both sliders at 100%.
MacXimus ( ) posted Mon, 17 June 2002 at 3:12 PM
Thanks all!
