Wed, Feb 5, 12:37 PM CST
Subject: "straps" or any other item that would twist from different angles
exorcism ( ) posted Thu, 20 June 2002 at 5:57 AM · edited Wed, 29 January 2025 at 1:09 PM
I'm trying to create something that would be a "strap" (like the ones on a backpack that hold it on your back) that twists a certain ammount to another angle (if you took that strap on your backpack and twisted it 45degrees one way) Any way to do this, note I don't have any other 3d programs to work with on this. Thanks! ps. also slightly related, this strap would be around a corner/edge, and right now I'm (very sloppily) cutting the edges off, anyway to actually "bend" the object around the corner with using the method I am (I'm having difficulty explaining it, but hopefully someine understands).
Erlik ( ) posted Thu, 20 June 2002 at 7:55 AM
Have you tried with symmetrical lattices? Erase the default one in the Preview window and try playing with drawing one that would look like it's twisted.
-- erlik
airflamesred ( ) posted Thu, 20 June 2002 at 4:58 PM
multi-replicate a small portion, latice, rounded cube - unless your view is close up its fine
Aldaron ( ) posted Thu, 20 June 2002 at 7:27 PM
This could possibly be done with metaballs too if you have Bryce 5.
johnpenn ( ) posted Thu, 20 June 2002 at 8:57 PM
Aldaron beat me to it. I launced Bryce after merely reading the title. Oh well. Yeah, it'll work, I did it but the offset was a little too high. But you get the idea.
