Fri, Jan 24, 6:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Subject: Will Tailor 1.1 convert Vicky's clothes for Voluptuous Vicky 2?
ronknights ( ) posted Sun, 23 June 2002 at 2:40 AM · edited Fri, 24 January 2025 at 5:46 PM
I can never get this straight. Will Tailor work with Voluptuous Vicky 2? I'd love to Tailor some of Vicky 2's clothes to fit for Voluptuous Vicky? Come to think of it can I convert Mike's clothes to fit Massive Mike and Musclebound Mike? They can't be naked all the time!
FWTempest ( ) posted Sun, 23 June 2002 at 4:07 AM
unless they're in a temple... with swords..... sorry, can't help, but couldn't resist being first to the pun. it's late
Mazak ( ) posted Sun, 23 June 2002 at 5:03 AM
Yes, Spawn morphtargets on vicky and save a new cr2 without the VV magnets :) Mazak
Google+ Bodo Nittel
eirian ( ) posted Sun, 23 June 2002 at 5:22 AM
Massive Mike and Musclebound Mike will work easily with Tailor. Volupuous Vicky and Steffy Stax are a little more complicated, because their morphs are based on magnets not MTs. You would need to load VV, get the body shape you want and then select each body part in turn, and spawn a morph target (Object Menu -> Spawn Morph Target). Give each MT a recognisable name. Then resave the .cr2. Import the new .cr2 into Tailor, and the new MTs can be transferred across to whatever clothing you like. (There is an easier way: Wyrmmaster's "Fitting Room" does the job for you. Of course, you have to pay for that.)
ronknights ( ) posted Sun, 23 June 2002 at 8:08 AM
OK, but if I understand correctly, the new version of Tailor will handle full body morphs. So I should not need to spawn individual morph targets for body partS? Voluptuous Vicky 2 (VV2) comes with some gizmos that theoretically fit Vicky's clothes on VV. I think the fitting room is an extension of that, using "form fitting" or something like that. I'm curious why Massive Mike would work easily, but VV2 would not. Weren't they built "on the same technology," using magnets? Of course, Massive Mike is "outdated," since there is not yet a Massive Mike Version 2. I have VV version 2 now. That might be a difference?! It's good to know I can Tailor clothes for Musclebound Mike. It's about time he earned his keep! Ron
eirian ( ) posted Sun, 23 June 2002 at 8:17 AM
I haven't tried Tailor with FBMs, Ron, but I would guess you would still have to create and transfer the individual morphs as well: FBMs aren't true "morphs", just a set of instructions linking morphs on other body parts. The reason it'll work with the Mike versions and not VV is because Massive Mike is distributed as a collection of morphs. They were created with magnets, sure, but the mags themselves aren't part of the distribution. VV is distributed as magnets and MOR poses. Magnets are not morphs...at least not ones Tailor can handle.
ChromeTiger ( ) posted Sun, 23 June 2002 at 8:31 AM
Lesse if I can answer this one intelligently and correctly: Massive Mike was distributed with all his adjustments included via Morph Targets. When you load him up, there are no magnets needed. Voluptuous Vicky (1 and 2) are distributed with the magnets still in place...they were not converted into MT's. This alloes for a great deal more flexibility in shaping VV2 than there is with Massive Mike. Now, Voluptuous Vicky 2 isn't that different from VV1, basically speaking. And it's actually pretty simple to get clothing to fit VV2 without having to buy the Fitting Room (though I highly recommend it). The main core difference is support for Victoria 2's additional morphs. Which is where Tailor comes into play. Here's the 'down & dirty' method I use for adapting clothing for VV2: 1. Load Victoria 2 as Base Figure (V2 is the base for VV2) 2. Load Target Clothing Item (remember to make sure it conforms well out of the gate) 3. Transfer the desired morphs from V2 to the Clothing (MUCH easier for FBM's with 1.1 now) 4. Save Clothing with different name (Ex. Olympian V2) 5. Load VV2 in Poser 6. Load Clothing and Conform to VV2 7. Use Fitting Room settings or manually adjust magnet zones to affect needed areas of clothing (Right Collar, Chest, etc.) Note: If you choose to use the manual method, one thing you have to watch: Make SURE the magnet zone you're adjusting covers the clothing area you're selecting! I've made some interesting goofs by making the Left Breast Mag Zone affect the right collar of the clothing...OOPS! 8. Once clothing has been adjusted as needed, hide or scale remaining VV2 body parts as necessary to remove poke-throughs (her shapely rear runs into this problem a bit...just Z-scale it down a few points to get it contained). Hope that's understandable...I've never really been much for writing tutorials... Anyway, that's the short-form of it. I'm working on Tailoring clothing for Massive Mike as well...nice to see that 'Massive' morph actually working on stuff now! ChromeTiger Very Satisfied Wyrmmaster and Tailor consumer. ;-)
ronknights ( ) posted Sun, 23 June 2002 at 9:14 AM
ChromeTiger, that was an excellent explanation. However, my feeble mind groans at the thought of doing the entire process. It appears I have a low "intricacy level." Maybe I'll make do with what I have. It appears that VV2 is able to handle more of Vicky's clothes with less fuss. Then later I'll buy that fitting room! *** By the way I'd be very interested in any clothing conversions you do make! On a side-note, is it possible to take some body parts or morphs from Massive Mike, and move them to Mike 2? I'm wondering about Massive Mike's "genitals," grin. Message671422.jpg
tiamatdx ( ) posted Sun, 23 June 2002 at 11:44 AM
Buy the fitting room, almost every vicky clothing works with it. Only need a little tweaking on some to make it look better.
