Attached Link: http://www.stoik.com/products/rubberpi/rubber.html
How's this?What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
If there is? I have never run across one that does what I have described above in PhotoShop v5 - that will distort on three levels at the same time. There are ones, which will perform and edit distortion on one level, and then you must change the settings. If so please post the name and path to the effect or filter? or is it a newer version of PhotoShop that has this great feature? Rubberman does what I want to do, but it would be more convenient to have it on a transparent, so you can see your map underneath.
That looks great Ron and the price is not bad...thanks... but can you add a trans layers to this item, if one could bring in a 3D model's UV Map underneath and then place the texture you wish to distort on top to fit. Seeing through the layers where to move the vertices of the "Warper" to the vertices of the UV map (which outlines the model) would be ideal. In Rubberman presently, one has to make an good educated guess, paste it on the map, and continuously check it against the model this takes a lot of time and results I do not think is as good. If some one could come up with this as a seperate little utility I bet they might make some $$$ Codetwister are you listening to this!? :-) Thanks again.. Ron I will be looking at it.
Mac - YES you CAN do that in PhotoImpact which has layers, masking, transparancies, and most everything in photoshop - go to the Ulead website and download a FREE demo. If you note the "preview" and "test" buttons in the interface above, these allow you to apply your settings to the full image without committing to it, tweak a bit, preview, tweak some nore, etc, and this can be done on a transparent or semi-transparent layer. I have actually used it to distort photos to fit UV templates and it works fine. There are also other "bend", "smear" and "distort" tools as well to aid this process. I make ALL my Poser textures in Photoimpact not in Photoshop even thouth I have both.
